need some help with my 5 speed
Old Nov 23, 2004 | 09:40 AM
Jeff583's Avatar
I pulled my tranny last night and found the input shaft bearing in pieces in the bottom of the tranny after i took the case apart so im wodering if anyone has a 5speed for sale that is in decent shape or were i can find a cheap overhaul kit for the tranny
Old Nov 23, 2004 | 11:34 AM
subs1000w's Avatar
www.drivetrain.com has a kit
Old Nov 23, 2004 | 03:02 PM
mtcookson's Avatar
yup, drivetrain.com is the way to go. before you order the parts check all of your bearings and make sure none of them are scored from the metal pieces going around in there.
in 2 trannies that i've dealt with the differential carrier bearings got scored so i had to replace those. also, don't forget to order the input shaft seal and the two axle seals to be on the safe side. be sure to measure all of the tolerances before putting it back together. i didn't give a care about measuring at the time and now my tranny whines as if i had a roots s/c on there
Old Nov 23, 2004 | 03:04 PM
95turbo gxe's Avatar
Well I did not rebuild mine( I dont think any one has) But dam it wines in first.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
