i have a stillen type 2 wing on my car but i think i burned the LED lights while hooking up a new stereo system one time. it don't come on no more when i hit the brake. you guys know any place on the web where i can purchase a new one, just the lighting?
Quote:
yeah, it look something like this...Originally Posted by Jeff92se
Stillen?............
http://stillen.com/Sportscars_detail...&id=323&page=1
stillen sells them for a bit too much. i think they call it 3rd brakelight housing (there was no picture). do you guys know any other places where i can get this lights, maybe just the bulbs. or the whole guage is cool too.
what he said
test and see that you're getting power before you jump to conclusions that all the bulbs are dead and you need a new setup...you could've snipped the wrong wire or something after your install
Actually, this is a good question, if indeed the bulbs are burned out. I am sure T93Max checked the fuses and connections, though, right?
I have a Stillen spoiler in my garage and three of the LEDs are burned out. My problem is the screws underneath are rusted and I can't get them out. Once I do, I will need to figure out what type of bulbs to replace them with. I was going to head down to Radio Shack and see if I could match them up, but if you find something more definitive, please post it.
i'm not axactly sure, but before, the brakelight works. i connected it using the brake wires in the trunk. i didn't even tamper with these wires while installing my sound system. the other brakelights still works though.
but while i was hooking up my new stereo and sound system (subs and amps too). i accidently cross the wrong wires at one point (there was a spark), and that burned some of the fuses. some of the interior lightning did not come on, but i fixed that though. i replaced the fuses and those lights works fine now except for the LED brakelight. i didn't run a fuse line for that brakelight therefore i believed i fried it. i'm gonna try testing it again. y'all think a D or AA duracell battery will lit it up??
Ad·min·is·tra·tor
it's set up for 12V...D or AA is 1.5V...you think it'll light up? it MIGHT*...but i doubt it. go pick up a volt meter and see if you get power from the 2 leads before you go crazy trying to find the light bar.Originally Posted by T93Max
i'm not axactly sure, but before, the brakelight works. i connected it using the brake wires in the trunk. i didn't even tamper with these wires while installing my sound system. the other brakelights still works though.but while i was hooking up my new stereo and sound system (subs and amps too). i accidently cross the wrong wires at one point (there was a spark), and that burned some of the fuses. some of the interior lightning did not come on, but i fixed that though. i replaced the fuses and those lights works fine now except for the LED brakelight. i didn't run a fuse line for that brakelight therefore i believed i fried it. i'm gonna try testing it again. y'all think a D or AA duracell battery will lit it up??
at first i though it was kinda fishy too cuz none of the LED lights comes on and there are a bunch of them in there. i thought to myself if i burned it, maybe only one or two aren't gonna lit. yeah, the stillen LED lights take a while to unscrew and you gotta use this small @SS crooked crew driver too. Originally Posted by Red92MaxSE
i don't trust radio shack's bulbs man. i bought a few for some of the interior buttons inside the car but they fried again right after you turn them on. i say hit the junkyard.
Quote:
thanks 4 da info. maybe it will lit up just a little bit.
Ad·min·is·tra·tor
c'mon man...unscrew the light...bring it to the front of the car...red to + black to - on the battery. if it lights then you know you have a wiring problem.
if it's dead then find a new light bar.
well if you do as DanNY says and they dont light up then here is a place that has some.
http://www.spoilerlights.com/
Also I just did a google search to come up with that. Do some more searching if this place doesnt have the right size.
Good luck finding a Stillen spoiler at a junkyard. Originally Posted by T93Max
at first i though it was kinda fishy too cuz none of the LED lights comes on and there are a bunch of them in there. i thought to myself if i burned it, maybe only one or two aren't gonna lit. yeah, the stillen LED lights take a while to unscrew and you gotta use this small @SS crooked crew driver too. i don't trust radio shack's bulbs man. i bought a few for some of the interior buttons inside the car but they fried again right after you turn them on. i say hit the junkyard.
AWSM66, nice find on the site. I hadn't really checked around, because I still need to take it apart, have the scratches filled and then get the spoiler painted. It's kind of low on my list of things to do, I just thought if someone had the part number or knew the exact replacement, I could have referenced this thread later.
Quote:
oh the irony Originally Posted by Red92MaxSE
Quote:
Technically, I found mine on ebay. Yeah, the car was a pile of junk...I don't think anyone else I can recall has found one cheap from a yard/ebay.Originally Posted by MrGone
oh the irony
I found one at a junkyard months ago.. they musta known what it was cause the bastards wanted $175 for it.... when they probably didn't pay that much for the whole car.
Quote:
Notice I said, "...found one cheap from a yard/ebay." Originally Posted by Matt93SE
I wouldn't really consider $175 cheap. Mine was $50 shipped off of some car that was in a nasty accident. The guy had the whole car for $100 on ebay, so I made an offer on just the spoiler.
It's funny how unreliable pricing is at a lot of junkyards. The U-Pull-It chain in Portland now has a huge board with fixed pricing on their parts. Before, prices were made using the "eyeball it" method. If it looked expensive, charge more.
dude, i went to u-pull it the other day to get an ignition coil pack for an escort and got it for $2.50. btw what's TD? Tigard?
Quote:
sounds like someone forgot to put some resistors on the ends...Originally Posted by T93Max
Brian
