Brake & Battery Lights Both ON + Rough Idle
Old Nov 25, 2004 | 09:42 PM
tool46&2's Avatar
This problem is not on my 94SE but is on my dads 92 SE 5spd.
The car hasn't been drove in a few months and really hasn't been drove daily for almost a year. Well he went to drive it yesterday and both the battery and brake lights on the dash are on. Also the car has a very low/rough idle around 500 rpm.
My dad said that he swapped batteries with a extra he had and the problem continued. He aslo said he checked voltage coming off the alternator and it was OK. (I can't verify any of the work performed or the exact symptoms of this problem, because this is just what I've been told and I haven't had a look at the car yet.)
I just thought I would post this and maybe get a heads up on the problem. I plan on taking a look at the car tomorrow or the next day.
Now I thought I remember reading something about this a year or two ago on the org forums, but couldn't remember for sure (Since I'm unable to search I couldn't find any old posts).
I thought when your alterantor was going bad sometimes the ABS and battery lights would come on, since the ABS control unit doesn't have enough power from the alternator, the ABS is the first thing sacraficed. But I could be mistaken on that. But this seems to be a little bit different since it's the battery and brake light coming on.
Any advice or tips would be greatly appreciated!!
Old Nov 25, 2004 | 10:07 PM
DMad8724's Avatar
Brake + Battery light is the indication of a dead/dying alternator, get that check out..
Old Nov 26, 2004 | 05:24 AM
bhunter's Avatar
On my 92 SE it was the battery and ABS light that came on when my alt was going and gone. The brake light did not come on.
Old Nov 26, 2004 | 05:39 AM
internetautomar's Avatar
mod or sell?
both are common to see come on when the alternator goes bad.
maybe his car doesn't have ABS
and BTW an alternator can put out the correct voltage and still be bad.
Old Nov 26, 2004 | 05:58 AM
DanNY's Avatar
Ad·min·is·tra·tor
sounds like alternator
Old Nov 26, 2004 | 06:22 AM
mod or sell?
I sell alternators
Old Nov 26, 2004 | 06:24 AM
3rdmaxse0's Avatar
before u check the alternator check the fuse labeled "eng cond" this fuse supplies voltage for o2 sensor, vtc, aicv,etc... and when blown will cause brake and battery light to come on together. be careful though that fuse blown for a reason. so if it blows again right away u got a short somewhere.and if that checks ok then its prob ur altinator.
tsi6001
Oct 3, 2022 10:23 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
