VE timming chain issue after VTC rebuild, Need some help guys
Old Dec 2, 2004 | 09:50 PM
  #41
eric93SE's Avatar
nope, I'm pretty sure the TSB on cleaning the gallies was for when the heads are off, where jets are pulled out. In the past i've ran motor flush's, so I hope any buildup was forced out, or just got stuck in the old tensioners. Also I tested the oil pressure a while back and it was high. Glad we don't get any oil pump failures in the VE
The engine is definitly functioning better with the new VTC springs, off the line I'm getting some nice tire spin.
Old Dec 2, 2004 | 10:03 PM
  #42
Mizeree_X's Avatar
Getting back to his roots
Originally Posted by Jeff92se
Did you get a chance to clean the oil gallies?
What do you recommend cleaning the gallies with without pulling the heads? Pipe cleaner? Test tube cleaner?
Old Dec 3, 2004 | 05:08 AM
  #43
Aaron92SE's Avatar
NWP Engineering.com
Nice job Eric. I'm glad you posted. I plan to fix my VTCs sometime this winter.
Old Dec 3, 2004 | 09:28 AM
  #44
eric93SE's Avatar
thanks, hey your lucky being in FL. I think I picked up a slight head cold while working in the garage.
Another tip, while the valve covers and timming covers are off, and before making your timming marks, rotate the engine so that the tensioners pop out. You especially need to do this if you plan on replacing the tensioner, otherwise trying to remove the tensioner in the compressed state is almost impossible, well I got it out and later realized how rediculous it was.
Mizeree_X, I think they make special tools to clean them, also there is a 'jet' that needs to be extracted prior to cleaning the galley.
Old Dec 3, 2004 | 10:15 AM
  #45
Aaron92SE's Avatar
NWP Engineering.com
I've heard of some people just using pipe cleaners to keep the oil gallies.
FL is nice in the winter. I can work on my car in 60-80 degree weather. But, I can't drag race my car in 40 degree weather like I could in NC sometimes. It just doesn't get 40 degrees often in South FL.
Old Dec 3, 2004 | 06:23 PM
  #46
beckysmaxima's Avatar
hey, can anyone tell me what postion to set the cams at, when doing the VTC setup, i got a 93 maxima with DOHC 3.0 litre..blah blah blah just any info as far as where to set the cams would be great..thanks!
Old Dec 4, 2004 | 02:38 PM
  #47
Jeff92se's Avatar
I'm needing a caw
Line them up according to the timing marks. If you don't have a factory fsm, get one
Old Dec 4, 2004 | 02:45 PM
  #48
MrGone's Avatar
it's not very useful
... better than nothing but still.
Old Dec 4, 2004 | 11:17 PM
  #49
Jeff92se's Avatar
I'm needing a caw
Ok. So what is better?
Old Dec 4, 2004 | 11:35 PM
  #50
MrGone's Avatar
nothing that I have found for the VE. Just having a general understanding of how valvetrains work aswell as motors in general and cams helps alot. But the FSM is very vague and your only real reference is a picture that is not 100% accurate
Old Dec 4, 2004 | 11:37 PM
  #51
Jeff92se's Avatar
I'm needing a caw
It's accurate as far as I know. If you think the Nissan FSM is bad, then you must think the Chiltons and Haynes is terrible. The factory FSM is actually pretty good. It's not vague. Might be confusing but the info is there.
Old Dec 4, 2004 | 11:46 PM
  #52
MrGone's Avatar
Chiltons/Haynes doesn't even tell you how to take out the back seat lol.
The FSM has lots of very very good info, I just feel that it is lacking in the valvetrain timing department thats all. (then again maybe I'm spoiled with the plethora of info with SBM/SBF/etc's).
Old Dec 5, 2004 | 01:32 AM
  #53
Jeff92se's Avatar
I'm needing a caw
WTH is sbm/sbf?
Old Dec 5, 2004 | 06:36 AM
  #54
internetautomar's Avatar
mod or sell?
WTH is sbm/sbf?
SBM= Small block mopar
SBF= Small Block Ford
Old Dec 5, 2004 | 08:33 AM
  #55
eric93SE's Avatar
I agree internetautomar
On the TSB for the VTC's the first blow up diagram is wayyyy off scale, the diagram for the body should be like 20% bigger, the way its shown it would never fit together. But all-in-all I'd say the FSM is adequate.
Old Dec 5, 2004 | 10:43 AM
  #56
Maximan190's Avatar
SBC =
Old Dec 5, 2004 | 11:32 AM
  #57
CandiMan's Avatar
Say Candyman 5 times
One thing you have to understand about service manuals is that certain manuals are design for certain individual. Haynes/Chilton are designed for your avg. at home DIY's while the FSM are designed for technician. When someone uses a FSM it's assumed that person has the ability to understand certain things without the FSM saying so, like taking out the rear seat. I just pick-up a Haynes for my S-10 truck and they really break it down and give actual hands on pics. In some of the pics you can see the grease under the guys nails, now how actual is that? The Haynes also gives you little tricks of the trade how to take apart certain things, while the FSM will only suggest using a "Nissan" tool to take apart things.
My $0.02
MIKE
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
