auto shifter locking up
i bought my max for $500 with rims drop kit exhaust and a blown auto tranny, im kicking myself for not doing a 5-speed swap when i had the chance because i bought a 93 auto tranny with 93k and did it myself... my only problem is that the shifter gets locked up and i have to push down the lock tab to get it out of park most times... this morning i couldn't take it out of drive unless i did that too..
ive heard that i tcould be something loose ontop of the cat.. don't know what it is or what i have to do... anyone wiht advice??
the worst part is that cuz we have no cupholders i dropped a biggy size coke on my center console and it got into the shifter and not that lock tab gets stuck.... but i was having this problem way before i spilled the soda
my suggestion is to pull the bezel and and check to make sure that voltage gets to the solenoid every time you press the brake pedal.
if it does then chances are the solenoid is the problem.
if it doesn't then check the switch by the brake pedal, it may be worn
HerpDerp1919
09-29-2015 02:02 PM
atriuum
09-28-2015 01:19 PM
