Power Window Cable
Old Apr 19, 2001 | 07:05 AM
David Maleski
The drivers side power window made a (plastic breaking) noise then fell inside the door. I took the panel off and found that the plastic stopper that holds on to the cable is broke. None of the auto glass places I called will help. If I had a picture of what the mechanism is suppose to look like, I might be able to fix it myself. Does Nissan sell this part or will I end up buying a new door. Should I just take it to the nearest Nissan dealer?
Thanks.
Old Apr 19, 2001 | 07:34 AM
DanNY's Avatar
Ad·min·is·tra·tor
you need a new window regulator. comes w/ the rails and wires and etc.. no motor. give courtesy nissan a call and see if they can help u out. ask for the max.org discount.
Thanks.
Old Apr 19, 2001 | 09:23 AM
deesel104's Avatar
here's instructions:
Here's a helpful link for installing a new window regulator. I followed these steps when I replaced mine and it was no problem at all. Good luck!
http://www.prism.gatech.edu/~gte671n/mymax.html
Old Apr 19, 2001 | 11:02 AM
«§»Craig B«§»'s Avatar
Re: here's instructions:
thanks for posting the link; however, those pics may or may not be working since geocities is gay
if they aren't , try https://maxima.org.uk and go to the common problems section where I have the exact same writeup
