Green Mark, Yellow Mark??
you'll have to check your injectors and see which came on there. if i remember correctly you can use either color as long as all of them are the same (no mixing up colors). i'll wait for someone a bit more savvy with the injectors to chime in on that though.
That is correct. the color does matter. It indicates flow rate.
Just keep them the same color and you will be ok. The paint mark will be on the body of the inj near the electrical connector(you may have to remove connector to see it).
if your gonna replace one and do it yourself then i reccomend just doing them all at the same time, if you have enough $ though. I remember doing this myself and when i was done taking it all apart i decided to just get all new injectors, because i didn't want to do it again for a while.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
RWCreative
Sep 21, 2015 11:01 AM
I sell the injectors.
