jwt ecu install. help?!?!
Old Dec 2, 2004 | 10:31 PM
Flipdoutmax93's Avatar
Destroying The Hopes And Dreams of Honda Owners Everywhere!
how does one get to the bolts on the back side to take out the ecu? i bought a used jwt ecu from someone and i am having trouble removing the two bolts at the back holding the ecu in. there is hardly any clearance back there to get a screwdriver or ratchet back there. Is that the only way to take the ecu out? Or Is there an easier way to go about taking out the ecu to replace it? Thanks
Old Dec 3, 2004 | 04:31 AM
Jeff92se's Avatar
I'm needing a caw
There are two 8mm bolts in back. I used a small box/open end wrench
Old Dec 3, 2004 | 06:31 AM
DanNY's Avatar
Ad·min·is·tra·tor
get a small box wrench behind there. you can get it turning and use your fingers to get the rest of it out...just a few spins. i did my ECU swap in the parking lot at work...so it shouldn't be that bad.
yes 4 8mm screws all around.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
