door locks
Old Dec 7, 2004 | 10:50 AM
whitemax28's Avatar
door locks
none of my door locks work. Could a regular locksmith take care of that? Would it be expensive?
Old Dec 7, 2004 | 10:58 AM
DanNY's Avatar
Ad·min·is·tra·tor
what do u mean none of the locks work?
do they not lock the door when you push the button? how about when you move the tab down manually? key problem?
Old Dec 7, 2004 | 11:11 AM
whitemax28's Avatar
none of the doors will open with the key.
Old Dec 7, 2004 | 12:54 PM
bhunter's Avatar
It sounds like your key is worn out. Can you get a new key make by the code that should be in your glove box? It doesn't make sense that both locks would screw up at the same time. Will the key open the trunk? Are you locked out? Anymore keys?
Old Dec 7, 2004 | 01:27 PM
DennisMik's Avatar
does the key turn, but it is very stiff, and the door unlocks but re-locks immediately? if so, you have a problem with the door lock timer.
Old Dec 7, 2004 | 02:05 PM
sackz23's Avatar
I've got that problem....
How does one go about installing/replacing the door lock timer? Thanks.
Old Dec 7, 2004 | 02:53 PM
bhunter's Avatar
fixing door lock timer
Take it out and resoldeer the connections around the relay. It is easy and described by Craig b and others. Look in the stickies
Old Dec 7, 2004 | 10:20 PM
dewmax007's Avatar
i have one door which doesn't un-lock with both the key and the door switch. i tried finding the lock timer, (consulted craigb's tutorial), but couldnt locate it. ideas?
Old Dec 8, 2004 | 01:35 PM
DennisMik's Avatar
The door that does not unlock either way may have had the rod fall off that actually operates the lock mechanism inside the door itself. you will have to take off the inside door trim panel to check it out and fix it.
the door lock time is under the dash to the right of the steering wheel, pretty much in line with the edge of the console. i don't think that the door lock timer is responsible for your one door not working.
Old Dec 8, 2004 | 01:47 PM
bhunter's Avatar
LEFTof the steering wheel.
Old Dec 8, 2004 | 01:59 PM
«§»Craig B«§»'s Avatar
RIGHTof the steering wheel
left side = stock alarm, time control unit
right side = door lock timer (92-94 only), cruise control computer
for US at least
Old Dec 8, 2004 | 07:30 PM
dewmax007's Avatar
thanks. i thought i checked out the lock arm actuator but it is worth another look
Old Dec 9, 2004 | 07:48 AM
whitemax28's Avatar
its not the key. None of the locks respond to the key. I think all my locks are gone.
Old Dec 9, 2004 | 07:51 AM
aziphrale's Avatar
My problems kinda like that as well. My key works for trunk and driver door but not the passenger. And i have to close all doors to lock it. if i lock it then close any door. It unlocks all the doors. Weird.
Old Dec 9, 2004 | 07:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
that's a feature..you don't lock y0 **** out.
Old Dec 9, 2004 | 08:41 AM
pete944/max's Avatar
My key is stiff in the door locks and doesn't work in the trunk at all. I was wondering if the trunk uses a different key.
bhunter, What code in the glove box?
Old Dec 9, 2004 | 08:52 AM
maximagxe90's Avatar
Hi,
probably your trunk lock is stuck,
when you use your key does it open the trunk,
if it doesn't then you have to use wd40 or some special grease on it in order for the lock to turn,
i had the same problem,
i had to use wd40 in order for the key to open the trunk,
Old Dec 9, 2004 | 09:40 AM
bhunter's Avatar
There is a key code to make new keys by that a dealer or locksmith can use. They usually give it to you with the warrranty book and also a little stick- on label inside the glove box. With that an exact new key can be made instead of going to a hardware store and getting a copy made of a worn key.
Old Dec 9, 2004 | 10:30 AM
There were no books or manuals with this car. I'll check for a label in the glovebox when I get home but I highly doubt if it's there.
Thanks for the tip, though!
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
