Water C ock Valve/Solenoid
Old Dec 7, 2004 | 03:25 PM
-shock211-'s Avatar
If I removed the water c ock valve/solenoid would it have a negative affect on my heat?
I would assume that it would open up the path to the heater core fully and the air/mix door would control the temp settings. correct?
My heat is garbage and it's getting too damn cold. I flushed the heater core, replaced the thermostat and bled the coolant system for air. The car was 3ft in the air and I ran the engine until I couldn't shake out anymore bubbles.
I've tested the auto climate control system (via FSM self diagnosis procedure) and it's operating fine. The only fault my system has is a malfunctioning sun load sensor. That's not a big deal though.
My only other ideas are to remove the heater core for a visual inspection and see how the heat is without a water c ock valve/solenoid.
I've officially lost my mind...
Any input here people?
Old Dec 7, 2004 | 03:42 PM
Matt93SE's Avatar
STFU n00b!
uhhhhh huhuhuh you saic c ock.
ummm, try removing it and see what happens. can't hurt anything. you can usually pick up some little Ts at the parts store for $2-3 that will allow you to just plug both hoses in and clamp it down. they have a little screw on cap on it to let air/water out as well, so you can bleed the system from that end too. cool stuff.
try that and see what happens.
Old Dec 7, 2004 | 03:51 PM
-shock211-'s Avatar
yeppers
i'll give it a try and we'll see what happens
Old Dec 7, 2004 | 06:38 PM
89maxaz's Avatar
I had mine out today- I put one of those Prestone flush T's in it's place for awhile. I'm having heat troubles too. Does that 3' in the air bleeding thing apply to all the Maxima's? Mine's an 89...
Old Dec 7, 2004 | 07:04 PM
internetautomar's Avatar
mod or sell?
it applies to 89 and 90 for sure.
91 there is doubt
92 up have a bleeder nipple on the intake
Old Dec 7, 2004 | 07:57 PM
maximagxe90's Avatar
Hi,
my heater works,
my coolant system was flush by a professional,
and the guys done the flush on my car bleed the system of air and put in fresh coolant and was done,
Old Dec 8, 2004 | 06:53 AM
-shock211-'s Avatar
but where's the fun in that?
Old Dec 8, 2004 | 07:46 AM
mod or sell?
Old Dec 8, 2004 | 11:12 AM
89maxaz's Avatar
Soooo, is there a possibility that my ENTIRE heating problem (or lack thereof) is due to air bubbles in the system?? Thinking back, I may have done some hose changing a year or so ago, just prior to when I started having this problem.
Wow. This is crazy.
Old Dec 8, 2004 | 11:18 AM
mod or sell?
very possible if you didn't bleed the system.
Old Dec 8, 2004 | 11:19 AM
89maxaz's Avatar
Crap. Wonder if I can find the procedure in my Chilton or Haynes manual...
Guess I better look!
Old Dec 9, 2004 | 05:14 PM
Foufyter's Avatar
looked and not in the haynes manuel for sure. 93 max and i tell you getting frustrated more the colder it gets.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
RWCreative
Sep 21, 2015 11:01 AM
