Pulsing lights & weight question
Old Dec 8, 2004 | 08:12 PM
ngp325's Avatar
I'm having a problem with every light on my car pulsing. Every light, headlights, map lights, dash, everything. The pulsing stops when I depress the brakes or put the a/c on full blast. Any ideas? Someone told me it might be a loose connection somewhere.
Also, how much weight can be put into a 92 gxe with stock suspension and all that without damaging it?
Any help on either matter would be greatly appreciated.
Old Dec 8, 2004 | 08:42 PM
avmaldo's Avatar
check your alternator and battery.
Old Dec 8, 2004 | 10:01 PM
ngp325's Avatar
I went to AutoZone to get some stuff and had them test the alternator while I was there and they said it was fine.
Old Dec 8, 2004 | 10:36 PM
ChrisCheezer's Avatar
well its called dimming.. and its a sign that somthing in your charging system is going bad.. get the batt. tested (I once did 4 tests 2 said it was ok.. then the last 2 said replace it) so if u got that tested dont think it's not the problem..
could be the alternator just as well... get everything tested agian...check your batt. terminals.. if u see acid, clean it well and maybe lightly sand paper the terminal to insure perfect contact. (battery acid could be a sign too)
Old Dec 9, 2004 | 12:03 PM
avmaldo's Avatar
if it's not the alternanter make sure the belts are at the right tension. and check your batt
Old Dec 9, 2004 | 04:30 PM
95turbo gxe's Avatar
Well you can put this much weight in it (About 500lb) But you will need turbo just to pull off a geo storm. Nah just kidding not that slow. But you can figure for every 100lb you add to a car your going to loose a tenth of a second on the 1/4 mile.
Old Dec 9, 2004 | 05:36 PM
xpl0sive22's Avatar
where exactly do u have that installed... not in the maxima right...?
Old Dec 9, 2004 | 10:22 PM
ngp325's Avatar
About the weight, im not really worried about racing. Just want to know how much can be put in without damaging the suspension.
Old Dec 9, 2004 | 10:28 PM
avmaldo's Avatar
i thought ther was a towing capacity of like 2500lbs or something not sure though.
maybe it was 3500, somewhere in that area. i read it on hear before someone will know exactly.
Old Dec 10, 2004 | 04:19 PM
wolfpack_5150's Avatar
Apple Pie Monster
have you replaced any bulbs lately? couldnt a dual filament/single filament in the wrong location do this?
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
spidgeon
Aug 18, 2015 05:46 AM
doobadoo
Aug 15, 2015 06:43 PM
