Cruise control not working
Old Dec 11, 2004 | 10:36 AM
probmxstyle's Avatar
On my new 94 SE the cruise control never worked since i got it. I replaced the actuator and cable off of my old car. The cruise control on my old car worked befor i got rid of it so I know the parts I put on are good. When I puch the switch to turn it on the LED on the switch turns on. but when I hit SET on the steering wheel no light on the dash comes on and the cruise control does not work. Any ideas?
Old Dec 11, 2004 | 10:59 AM
DMad8724's Avatar
well if the light comes on, and when you hit the switch nothing happens, id suspect something in the switch
or maybe the light in the dash is out and it is working, you just havnt realized it
Old Dec 11, 2004 | 11:15 AM
whitemax28's Avatar
check the relay box under the coolant container.
Old Dec 11, 2004 | 11:57 PM
alpicone's Avatar
If your car is a 5 spd check to see that the pedal is going all the way up and hitting the switch. Look under the dash and you will see there are two switches that the clutch should touch. One when the pedal is al the way down which is the interlock switch. And the other when the pedal is all the way up (forgot the name). Basically this lets the cruise control know if you are on the clutch pedal. When the cruise is on if you press either the brake or clutch pedal, it will cancel the cruise. So if the pedal isnt touching the switch then the cruise thinks you are on the pedal and it wont set. I hope you understand what I am trying to say.
Watch him say he has an auto after I typed all that.
Old Dec 12, 2004 | 01:25 PM
I have a auto
J/k its a 5 sp
Old Dec 12, 2004 | 02:55 PM
alpicone's Avatar
Originally Posted by probmxstyle
I have a auto
J/k its a 5 sp
Well, did you check the switch?
Old Feb 6, 2006 | 08:47 PM
crazy4maxima's Avatar
same thing with me. My cruise control button lights up on the dash (turn on turn off) but when I press the set cruise the light on the dash board will blink on and off. any ideas.?
Old Feb 6, 2006 | 09:46 PM
proventech's Avatar
i just bought my 91 max on Sat and my cruise wont turn on at all. heck, half the things dont work right, but i'll start trying to get them to work this weekend. lol
by the way, any one know where to get an owners manual? thanks
Old Feb 6, 2006 | 10:29 PM
I narrowed my problem down to a faulty pin switch on the brake pedal. The contact point was broken inside and was telling the cruise control system that I was using the brakes which kept it from engaging. Talked to courtesy parts and the oem replacment is about 20 bucks last time i checked.
Old Feb 7, 2006 | 07:56 AM
jewsonlot's Avatar
i found mine on amazon very cheep
Old Feb 7, 2006 | 09:32 AM
mthomas002's Avatar
On mine there a little button behind the brake petal that was stuck I pull it with so plyer and its been good.
MikesChevelle
Nov 23, 2024 11:17 AM
stevesmax
Dec 17, 2020 11:57 AM
trasmadean
Feb 1, 2017 08:20 PM
schmellyfart
Sep 25, 2015 04:47 PM
MikesChevelle
Aug 6, 2015 11:36 AM
