who has rebuilt there manual tranny
Old Dec 19, 2004 | 05:23 PM
Jeff583's Avatar
have a question about the interlocking check *****, i need to know what order they go in on the syncro shafts, so any help would be appreiciated
Old Dec 19, 2004 | 07:11 PM
3rdmaxse0's Avatar
looking at my FSM it looks as you install input shaft and mainshaft with 1st & 2nd shift fork assembly. then install first set of interlocking ***** and plunger than install 3rd & 4th shift fork and bracket, then install 3rd and 4th shift rod, stopper ring and retaining pin, then install rest of interlocking *****, install 5th shift fork and bracket then install shift rod stopper ring and retaining pin.
Old Dec 20, 2004 | 01:07 PM
Jeff583's Avatar
any way you could get a diagram to better explain it to me
Old Dec 20, 2004 | 02:15 PM
James92SE's Avatar
2 VE's are better than one!
How in-depth a rebuild did you do?
Old Dec 20, 2004 | 02:27 PM
«§»Craig B«§»'s Avatar
not to be an a$$, but if you're rebuilding a tranny, you might want to invest in a FSM
Old Dec 21, 2004 | 09:00 AM
Jeff583's Avatar
well in one of my haynes manual it has an exploded view of the transmission but i have found that some of the parts are not the same
Old Dec 21, 2004 | 09:04 AM
Jeff583's Avatar
I replaced all of the bearings, bearing races, bushings, and all of the interlocking check *****
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
