Screeching at idle and PS fluid leaking
Old Apr 22, 2001 | 01:00 AM
socos
Howdy, recently the family Max (1989) started leaking PS fluid. I tightened a few hoses up, but now it has developed a screeching noise and fluid squirts out of a hose attach to a device hanging off the firewall (passenger side).. I'm guessing this is the power steering pump? Was there supposed to be a clamp there at one time or will that whole hose need replacing?
Old Apr 22, 2001 | 06:22 AM
brubenstein's Avatar
That's some sort of junction for the high pressure side of the system; it is not the pump. If it is leaking from the fittings, then you need new washers (they are special ones). If the leak is from a hose, you need a new hose. The noise is probably a combination of, low fluid, air in system, partially blocked internal filter.
Replace the leaking parts and flush/refill the system. P/S systems need their fluid changed every so often (5 yrs) to keep them from developing problems.
Old Apr 22, 2001 | 07:06 AM
Pervis Anathema's Avatar
What kind of problems do they develop? Does the old fluid build up debris which clogs the system?
Old Apr 22, 2001 | 12:30 PM
Yep, the crud will also wear things out. The fluid probably also breaks down with time: it gets hot enough for there to be a cooler for the fluid.
Unclejunebug
Apr 2, 2016 05:42 AM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
