Crankshaft pulley is stuck, Any suggestions?
Old Dec 22, 2004 | 05:15 PM
DGruber 58's Avatar
i've been doind some work and ended up taking the timing belt off a camshaft pulley. To get it back on I need to remove the crankshaft pulley so I can get to the timing belt adustment. I can't get the pulley off though. The manual says it should just wiiggle off or maybe a little prying with a screwdriver. I hit it with some PB blaster and had a three jaw puller on it, but still nothing. I have managed to chip a lip on the pulley, but that's it. Any help would be greatly appreciated.
Old Dec 22, 2004 | 05:36 PM
goon9's Avatar
Mine was stuck too. I used alot of PB blaster and rented 3 different pullers from autozone to get it off. I donno the name of the puller i tried, but just try another. I didn't have anything left to my outer lip either...
Old Dec 22, 2004 | 05:37 PM
HTPerformance's Avatar
What I have done on my VG was to tap the center with a rubber mallet and then work it back and forth with 2 screwdrivers in between the back of the pulley and the block.
Brian
Old Dec 22, 2004 | 06:04 PM
blacks92seAuto
cursing alot usually works for me
Old Dec 22, 2004 | 06:09 PM
DanNY's Avatar
Ad·min·is·tra·tor
try getting a bigger gear puller.
Old Dec 22, 2004 | 06:22 PM
alpicone's Avatar
Ya, auto zone has a few pullers. Get the biggest one the have. That's what I used to get mine off.
Old Dec 27, 2004 | 07:29 AM
DGruber 58's Avatar
I've got a 6 or 7 inch puller, but still nothing. Last night I soaked it in PB, then tried pulling but nothing. A couple broken lips but that's it. I left the puller on overnight, so it might have done something but I doubt it. Which lip should I pull from? First I tried the middle pulley's lip, but it was too thin and broke. Now it's on the thicker lip between the first and second pulley (compressor and alternator pulleys, I believe). Any suggestions?
Old Dec 27, 2004 | 08:27 AM
i know on the VE there are 2 holes for the puller that you screw into the pulley, I forget if the 2 holes are on the VG pulley. If they are you might have better luck with that type of pulley puller.
Brian
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
