My new muffler.
Old Dec 28, 2004 | 06:27 PM
goon9's Avatar
My new muffler.
G35 stock muffler. I should have it installed before the weekend.
It has 2 4" tips.
Old Dec 28, 2004 | 06:58 PM
MrGone's Avatar
its like a camaro muffler
Loe max's Avatar
I have an idea on how to mount it if you have trouble
Old Dec 28, 2004 | 06:59 PM
MrGone's Avatar
...on a G35?
Old Dec 28, 2004 | 07:01 PM
Loe max's Avatar
Originally Posted by MrGone
...on a G35?
VE30DE
Old Dec 28, 2004 | 07:07 PM
MrGone's Avatar
VE30DE
you just jacked my smilie
I'm curious to see if that clears the spare tire well
Old Dec 28, 2004 | 07:10 PM
Loe max's Avatar
You can mount it like this
Old Dec 28, 2004 | 07:27 PM
goon9's Avatar
Good bye wheel well for sure.
Old Dec 28, 2004 | 07:58 PM
Loe max's Avatar
I'm anxious to see how you are going to pull it off
Old Dec 28, 2004 | 10:02 PM
ChrisCheezer's Avatar
At first i didint see how that muffler and the one we were looking at were the same? but now i understand... should make for a good custom set-up.. can't wait to hear/see it done! good luck.
Old Dec 29, 2004 | 06:39 AM
«§»Craig B«§»'s Avatar
what kind of car is that? I'm guessing mini-van from the rear beam suspesion
Old Dec 29, 2004 | 06:48 AM
Wiking's Avatar
I'd guess a flight training multipurpose vehicle. I'm guessing from the yellow jack beam suspension...
Have done some updates at wikingboat home, lukiluki...
Old Dec 29, 2004 | 11:21 AM
aziphrale's Avatar
Im looking into getting a new muffler as well got an exhaust leak on the muffler. i was wondering whats the best performance muffler i can get. i would like to get that setup with the dual exits too. but i think it will cost too much. i dont need the pipe or new cat just a muffler. Anyone have any idea's? I saw some stuff on ebay but dont know if its worth it. and if it a piece of crap that will explode. lol. Any ideas will be thanksful. Sorry for thread stealing. Dont hurt me please..... Momma?
Old Dec 29, 2004 | 12:43 PM
alpicone's Avatar
The daul exhaust setup you saw a few posts up is a Flowmaster 80 Series muffler made for the Camaro. You would need an exhaust shop to bend some pipes for you or I believe there is a kit for a setup like that. But a muffler shop would prob come out cheaper.
Old Dec 29, 2004 | 01:21 PM
Loe max's Avatar
The kit that custommaxima sells are IIRC only for 4th-5th gen models so you'll off on your own for a custom set-up. I think using the flowmaster diagram above would a great choice because no denting of the spare tire well is required. If you look at the space around the drivers side of the spare tire well, there is enough room for at least a 2" pipe while still having enough room to compensate for exhaust movement.
Old Dec 29, 2004 | 01:25 PM
Maximan190's Avatar
that setup is possbile and it wont cost you the spare tire well if the pipes are ran correctly
the pipes on the G muffler need to be chopped off close to the muffler itself because the existing bends are not going to work except for the left outlet since that is already bent in the correct direction to run over to the driver side
Old Dec 29, 2004 | 01:34 PM
DanNY's Avatar
Ad·min·is·tra·tor
but chopping the pipes and extending it would change the sound a bit...no?
Old Dec 29, 2004 | 01:51 PM
internetautomar's Avatar
mod or sell?
Bingo!
Old Dec 29, 2004 | 05:33 PM
goon9's Avatar
OK, I did it. YEs it cost me the spare wheel well and saved me on weight.
I did it in a hury so I have a single leak somewhere.
It's too dark for pics right now, I'll have a few up 2mroro.
Old Dec 29, 2004 | 11:38 PM
Vadim-93GXE
Awesome! Sorry to hear you had to cut through the spare wheel well though. But as long as you didn't need to change the exhaust size, it should be good. So you gotta post pics man!
Oh, and how does it sound? Does it have that signature G35 growl? Nice. (double thumbs for double exhaust)
Old Dec 30, 2004 | 06:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
i thought the goal was not to chop the spare wheel well. if the wheel well didn't matter than you could've put anything there.
Old Dec 30, 2004 | 07:03 AM
aziphrale's Avatar
Bingo!
what muffler is that ? I like :smile:
Old Dec 30, 2004 | 07:07 AM
DanNY's Avatar
Ad·min·is·tra·tor
http://www.toucanindustries.com ??
Old Dec 30, 2004 | 07:23 AM
mod or sell?
that picture is from toucan AKA Ractive, but ANSA also makes a very similar one.
The toucan is $100
I'll probably buy it for mine
Old Dec 30, 2004 | 08:08 AM
Brad92SE's Avatar
This looks like an interesting setup! Anxiously awaiting pics.
Old Dec 30, 2004 | 10:08 AM
and maybe some sound clips?... if u get the leak fixed
Old Dec 30, 2004 | 10:41 AM
icepick's Avatar
leak oh my god captain we're sinking ahory matie
Old Dec 30, 2004 | 11:44 AM
HTPerformance's Avatar
Donde estas tus picturas???
Brian
Old Dec 30, 2004 | 03:34 PM
goon9's Avatar
I got home late from looking at a house, i'll have some daytime pics up later.
Old Dec 30, 2004 | 03:50 PM
Loe max's Avatar
What did you use to hold the pipes in place? I would like to know. Looks great
Cutting a whole in any part of your structure compromises rigidity though.
Old Dec 30, 2004 | 03:53 PM
goon9's Avatar
The hole will be filled and I'm going to tighten all that up. If you ever looked ur maxi you would understand I didn't weaken anything. The pipes are spot weld and held with clamps.
Old Dec 30, 2004 | 04:25 PM
icepick's Avatar
hey how does it sound???????
Old Dec 30, 2004 | 04:32 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
looks nice but ill never cut out the wheel well. ill have a shop mandrel bend pipes to fit...
Old Dec 30, 2004 | 04:34 PM
goon9's Avatar
It's not as loud as I thought it would.... Then again... It's hard to tell siting on the inside, anyone wanna do a drive by for me me? lol. But it's very noticable. Sounds great though, very throaty growl at a higher note. Sounds racy and less farty.
Old Dec 30, 2004 | 04:35 PM
goon9's Avatar
Yeah, when I get a y-pipe, I'm going to fix a couple manifold studes and a cat with less restriction and go 2.5 from the cat to the muffler, TILL THEN it's a chop job.
If anyone goes with a g35 muffler the wheel well has to go, there's no manderaling around it.
Old Dec 30, 2004 | 05:10 PM
-does it sound anything like a 350z or g35?
Old Dec 30, 2004 | 05:15 PM
goon9's Avatar
YEs it does sound like a g35, a slightly weak one. If I lose the cat it should be louder.
Old Dec 30, 2004 | 06:05 PM
Did you cut the WW rear???? Ick...
Old Dec 30, 2004 | 06:24 PM
aw89maxSE's Avatar
Old Dec 30, 2004 | 06:43 PM
goon9's Avatar
Originally Posted by aw89maxSE
Are the pics notloading? scroll down.
