problems after fuel injector replacement
Old Dec 30, 2004 | 01:47 PM
Brizine's Avatar
I have a 91 maxima se. I just replaced the #2 cylinder fuel injector. Put it all back together and now it runs like ****. It won't idle and runs rough unless I give it a lot of gas. I double checked the fireing sequence and looked all over for a vacumn hose that I might forgot to hook back up. Any suggestions?
Thanks Brian
Old Dec 30, 2004 | 01:59 PM
shavedmax's Avatar
vacuum leak somewhere, did you replace the manifold gasket? get some starter fluid and spray it around any seam that you took appart to see if t's leaking. if the car runs better when you spray the seam them there is a vaccum leak there(the starter fluid is getting in) hope that helps
Old Dec 30, 2004 | 02:19 PM
internetautomar's Avatar
mod or sell?
any flamable aerosol or gas will work.
we prefer propane at the shop, but I've seen carb cleaner used as well, just use those stupid little straw thingies to have a more pinpoint location
Old Dec 30, 2004 | 02:45 PM
alpicone's Avatar
You can also use WD-40.
Old Dec 30, 2004 | 06:01 PM
Brizine's Avatar
replaced lower intake manifold gasket and fixed the problem. Thanks for all the replies. Brian
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
homewrecker
Aug 24, 2015 08:56 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
