I need some help please........
I just got done doing a head gasket replacement on the left side (radiator side) of my 92 VE engine. I had no problems and followed the manual to the tee on tighting bolts, ect. The engine starts and runs, but misses real bad, and it it running really, really, rich. I will foul out the plugs almost right away. The is a lot of black soot on the plugs and a lot of soot in coming out of the tail pipe. Does anyone know what is causing this?
update
The engine is flooding really bad. So bad , that the gas is coming out from the tailpipe. The plugs are really gas soaked. I checked for spark and it is getting spark, just way to much gas. Help please!
the #2 cylinder would not fire. I checked/changed the injector and still would not fire. After a while white steam started to come out of the tail pipe, and when I checked the plug it looked like it been washed. The cylinder also was a little low on compression. When I got the head off, I found a "soft spot" on the gasket near the cylinder wall, looked like coolant was getting it the cylinder. The top of the piston was "clean" and the other two had the uasual carbon on them. I took the head and had it cleaned and milled. It was warped pretty bad. I reused the injector seals , I was told by the parts guy at Nissan that they seldom change them when they pull a fuel rail. ALL my plugs are gas soaked....what could cause the injectors to be stuck open?
I didnt have a flooding issue before I did this job.....what could cause the massive engine flooding?
Would a defective fuel pressure regulator cause this? Can they stick "open". How can you check it for proper operation? BTW, I have NO check engine light on?!?!
Mr. Rose
Jan 6, 2001 10:24 AM
