ABS Actuator Assembly Leaking
Old Jan 3, 2005 | 09:52 AM
bal4833's Avatar
I have found the actuator assembly is leaking brake fluid. The brakes have felt kind of soft to me, now I know why. Do I have to replace the entire unit? Any good guides out there? The Haynes book I purchased does not cover replacing this component.
Old Jan 3, 2005 | 09:58 AM
Jeff92se's Avatar
I'm needing a caw
Should be replaced. The autozone manual in the stickies that I'm sure you checked doesn't have it for the VG. You might have to get a Nissan fsm.
Old Jan 3, 2005 | 11:27 AM
twinkle's Avatar
Yea, the same thing happened on my VE before i wrecked it, its probly a lil rubber seal that should cost like $2 but nissan wants $1100 for the whole unit....I picked one up at a U pull it for $100 so its up to you
Old Jan 3, 2005 | 02:54 PM
Vadim-93GXE
Does the unit itself differ for a VE or VG?
Old Jan 3, 2005 | 02:59 PM
LMaRiE91MaXiMa's Avatar
Now I know this is going to sound dumb, but please bear with me...What is the actuator assembly??
I ask because about a month or so ago my e-brake light began luminating intermittently and I couldnt figure out why until someone told me to check my brake fluid. Turns out that's all I needed. However, I do know that you should NOT have to fill your brake fluid unless there is a leak...I have not and still do not see any puddles on the ground and was wondering if maybe I have a leak in the "acutator assembly"....except I don't know what that is!! Can someone please let me know and tell me where I should look for this part? Or...any ideas on where else I should look for a leak in brake fluid? The leak HAS to be minor because like I said, I do not see any fluid anywhere (inside or out) and I have not had to fill it up again since... Thanks everyone!
Old Jan 3, 2005 | 03:45 PM
bal4833's Avatar
On the 93 model, the actuator is located in the engine compartment at the front on the right side of the car. In 95 they apparently moved it to be near the master cylinder. Not sure on the 91. You should be able to find it because it will have a number (greater than 8 ?) tubes connected to it. The tubes go to each wheel. A low level in the MC resevoir is what lead me to start looking.
Old Jan 4, 2005 | 07:23 AM
thanks for your reply...at least i have a few places to check! (Or my boyfriend to check I should say..hehe)
Old Jan 4, 2005 | 11:23 AM
Vadim-93GXE
Old Jan 4, 2005 | 01:28 PM
MaXtUneD's Avatar
Yea, thats where mine started to leak, than it would start to shoot out., Just replace the unit and you'll be fine..best thing to do is go on car-part.com and search for the part.Or check your nearest local junkyard..
Old Jan 5, 2005 | 03:09 PM
lalo's Avatar
MAXTUNED that is one sweet turbo charnged engine
usually you cant fix an abs pump you would have to buy the hole new previously owned part, but they are not that expensive. and installation is prety simple just as long as you dont forget to bleed your brake system after install.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
atriuum
Sep 28, 2015 01:19 PM
Noela
Sep 26, 2015 08:22 AM
