broken speedometer
Old Jan 5, 2005 | 03:00 PM
gregor4's Avatar
broken speedometer
I was driving down the highway today and my speedometer just stopped working. I suspect that the cable ends are bad somewhere. But I can't find where the cable is. I looked in my Haynes manual and still can't find it. Anyone replaced this before? Anything else it could be? Every other guage in the dash works except the speedometer and the odometer. Thank you in advance!
Old Jan 5, 2005 | 03:53 PM
internetautomar's Avatar
mod or sell?
there is no cable.
you speed sensor probably needs to be pushed back in
Old Jan 6, 2005 | 06:07 AM
-shock211-'s Avatar
indeed...no cable.
it's a common problem for the speed sensor to fail or for the speedometer unit behind your gauges to screw up. i repalced my speed sensor after having the same issue and it didn't fix things. i then replaced the speedometer itself and now i haven't had any problems.
Old Mar 29, 2010 | 10:19 PM
maxinout93's Avatar
How do you replace the speedometer speed sensor. I need to replace mine. It goes up to 15mph and then stays at 45mph all the time. What do you do after you unscrew that one 10mm bolt that holds the speed sensor onto the transmission? Do you just pull it up of twist it out?
Old Mar 29, 2010 | 10:32 PM
Hectic's Avatar
Yeah but it can be easier said than done. Twist, and pull up, watch out for gear oil.
Old Mar 29, 2010 | 11:39 PM
chrome91's Avatar
for anyone else reading this 5 year old thread lol it could be a solenoid on the back of the cluster as well, its replaceable and IIRC Radio Shack or places like them will have what you need and you just solder it in
i need to fix mine, RPM cuts in 1/10th of the time now and temperature cuts in half of the time. for me it would be cheapest to just get a junkyard cluster for $12 but i would want a SE one and none ive come by have a ABS light on them and i need one with ABS
Old Mar 30, 2010 | 08:57 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i would tend to think that if you had an issue with the speed sensor that it would read 0mph rather than giving false readings. I would lean more toward the problem being the gauge itself rather than the speed sensor. you can verify this by trying to use cruise control (if cruise control previously worked) and also if the odometer works properly then so does the speed sensor.
then get a JY gauge cluster and just swap the gauges themselves into your current cluster shell, so your ABS light still works
Old Mar 30, 2010 | 09:00 AM
pic? you sure you aren't thinking about the chime unit? that goes "clink clank.... clink clank"?
Old Mar 30, 2010 | 10:22 AM
chrome91's Avatar
someone had pics up of them doing the solenoid, their RPM needle was bouncing randomly like mine did before it basically died and a solenoid had problems, replaced it and it works
i might run to the junkyard today then and get that SE cluster if i can just swap the gauges themselves
Old Mar 30, 2010 | 10:54 AM
i'd like to see just what solenoid you're talking about... you sure you didn't mean capacitor? this is a capacitor
and i think this is the thread you are talking about
http://forums.maxima.org/3rd-generat...cing-tach.html
Old Mar 30, 2010 | 10:57 AM
chrome91's Avatar
yeah, thats it. i could have sworn solenoid was mentioned, but guess not
Old Mar 30, 2010 | 04:08 PM
96nismoSE's Avatar
^^just leave you are no help at all......b1tch....
Old Mar 30, 2010 | 11:33 PM
maxinout93's Avatar
lol everything on the SE cluster I swapped out works except for the speedometer and the odometer.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
MR2 T'd
Jul 9, 2021 05:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
