car wont go in reverse very easy.
Old Jan 8, 2005 | 01:29 PM
tripleGmax's Avatar
Ive got an Automagic transmission and i know that this has been covered before, but my car has to be pushed just right for it to go into reverse. I remember it being something easy to fix. Could anybody refresh my memory so i could fix this soon. its annoying.
thizzanks.
Old Jan 8, 2005 | 03:59 PM
90maroon15.1's Avatar
i have a similar problem but i have to jiggle the shifter to get it to catch into reverse
Old Jan 8, 2005 | 08:38 PM
tripleGmax's Avatar
thats what im talkin about. I know there was a discussion awhile ago about the easy way to fix it. just want to know what it is. its annoying.
Old Jan 8, 2005 | 09:05 PM
Governor's Avatar
it is the shifter bushing..mine is bad also..u can cheat it a little by moving lock nut back a little on shifter linkage and tighten back up...
Old Jan 8, 2005 | 09:11 PM
Jon91SE's Avatar
Pusssseeeehhhh
Shifter bushing it is right on the money.
Old Jan 9, 2005 | 09:14 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
cheap part and a cheap fix. get it taken care of. when i bought the max years ago, the bushing was so bad i could knock the car out of D and into N etc if i wanted to
Old Jan 9, 2005 | 10:03 AM
twinkle's Avatar
Arn't you supposed to be able to do that, every car I can remeber driving is like that, and besides it makes neutral slamming a whole lot easyer...
Old Jan 9, 2005 | 12:40 PM
xpl0sive22's Avatar
yeah u can knock any car's transmission from D into N... so u mite've replaced the burshing for nothing... but i also have a problem when i put it into D, it doesnt engage, so i have to tap the shifter backwards a bit, and then it catches on... is that a problem wit the brushing also?
Old Jan 9, 2005 | 05:04 PM
Ivan Yulaev's Avatar
Exactly what I have. I just learned to go back into 2nd, and then into D.
Old Jan 9, 2005 | 06:25 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
xpl0sive...
simply knocking a shifter into N or in my case it could easily and i stress easily be tapped althway into R. seems pretty dangerous don't you think? i'm about 500% positive i didn't replace a cheap part for nothing...
twinkle...neutral drops are pretty healthy for your tranny.....good luck with that
Old Jan 10, 2005 | 05:35 AM
tripleGmax's Avatar
cool, ill get that taken care of as soon as possible. thanks for chimin in everybody. I cant wait for this snow and cold weather to peace out.
Old Jan 10, 2005 | 08:01 AM
LMaRiE91MaXiMa's Avatar
Hey this is a little off subject, but not quite....I have an automatic transmission as well, and while I have no problem switching into reverse, etc while the car is already in gear - I do have a problem shifting it out of park.
normally I have to depress the brake pedal to "unlock" the shifter and then I can push the button on the shifter and switch it out of Park and into gear.. Lately I've noticed that sometimes the thing in my brake does not unlock the shifter and then I have to use the manual override button located on the front and very bottom of the shifter to get the dam thing outta park! (Nissan must have anticipated this issue..thus why they put the override button there..hehe)
Anyway, does anyone know why this could be happening? Please let me know Thanks!
Old Jan 10, 2005 | 08:32 AM
internetautomar's Avatar
mod or sell?
does it always click when you press the brake pedal?
Old Jan 10, 2005 | 03:03 PM
hadman's Avatar
I also get the anti-click 'sometimes' when I depress the break to release from Park.
I figured it was the shifter solenoid, but I've been lazy getting around to it as it's not a total annoyance just yet.
Old Jan 10, 2005 | 05:53 PM
Kourtak's Avatar
Hi - how do you order a shift lever bushing? Could someone please send instructions on replacing it - or is it that simple?
Old Jan 11, 2005 | 07:33 AM
When the thing is actually working it always clicks when I press the brake pedal, but when its not working there's nothing (no sound) but my foot pushing the pedal...
Old Jan 11, 2005 | 07:36 AM
What is a shifter solenoid? And how much does this cost? Could I replace it myself? Maybe thats my prob.... My Max has been doing this on and off for about a month or 2 now...I've just never gotten around to asking anyone about it cause I dont want to spend anymore money than I have to, and at this point it's not a major nuisance, but sometimes, when I got my hands full - its a pain in the *** to have to push the override button and push the shift selector to move the dam thin. If it was cheap and I can fix it myself, I'd do it.
Old Jan 11, 2005 | 07:39 AM
mod or sell?
so start by checking to see if the solenoid is recieving the power to engage / disengage.
then if that doesn't check out, check the switch at the pedal.
Old Jan 11, 2005 | 07:40 AM
mod or sell?
the soleniod is by the shift lever under the cover.
Old Jan 11, 2005 | 10:16 AM
DennisMik's Avatar
If you're not getting power to the solenoid, then chech the switch on the brake pedal.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
spidgeon
Aug 18, 2015 05:46 AM
Trin1j23
Aug 12, 2015 08:31 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
