mph in each gear
mph in each gear
Thought this might help those 5speed VE guys. Someone correct me if Im wrong?
1st= 3.285
2nd= 1.850
3rd= 1.272
4th= 0.954
5th= 0.795
Reverse= 3.429
Final Drive Ratio= 3.823
MPH=(engine RPM X Tire Radius) / (Final Gear Ratio X 168)
Engine rpm =6,550rpms
Tire Radius (inches): aspect ratio(205 X .65=133.25)X .0394 (mm to inch conv.) = 5.25in
5.25 + 15(rim size) X .5
5.25 + 7.5=12.75
Final Gear Ratio: gear ratio (3.285=1st gear) X final drive (3.823)=
12.558555
MPH = (6,550 x 12.75) / (12.558555 X 168)
MPH = 83512.5 / 2109.83724
MPH=39.58mph@6,550rpm in 1st gear
MPH/RPM= MPH / (rpm /1000)(about 6.04mph/1,000rpm)
Taking that same equation and use that for 2nd gear
MPH = 83512.5 / 1.85 X 3.823 X 168
MPH = 83512.5 / 1188.1884
MPH = 70.29mph@6,550rpm in 2nd gear(about 10.73mph / 1,000rpm)
Again for 3rd gear
MPH = 83512.5 / 1.272 X 3.823 X 168
MPH = 83512.5 / 816.959808
MPH = 102.22mph@6,550rpm(about 15.61mph / 1,000rpm)
4th gear
MPH = 83512.5 / .954 X 3.823 X 168
MPH = 83512.5 / 612.719856
MPH = 135.30mph@6,550rpm(about 20.66mph / 1,000rpm)
5th gear
MPH = 83512.5 / .795 X 3.823 X 168
MPH = 83512.5 / 510.59988
MPH = 163.56mph@6,550rpm(about 24.97mph / 1,000rpm)
Reverse
MPH=83512.5 / 3.429 X 3.823 X 168
MPH=83512.5 / 2202.323256
MPH = 37.92mph@6,550rpm(5.79mph / 1,000rpm)
1st= 3.285
2nd= 1.850
3rd= 1.272
4th= 0.954
5th= 0.795
Reverse= 3.429
5.25 + 7.5=12.75
12.558555
Again for 3rd gear
4th gear
5th gear
Reverse
This should stop all the how fast can I go threads. lol (My first post) Dude you must've been bored or found some internet calculator. Can you do this for the VG's also. The max speed should be around One Fitty.
All I had to do was figure out Part A which would be a constant since overall tire diameter and rpm would not change in the equation and divided by Part B, which does change.
Keep in mind this is just the top speed in each gear, it does not mean you car will reach those speeds in 5th gear, or even 4th gear (for you VG guys
)Another purpose for this math is knowing how many MPH/1,000rpm. This could possible help you rev match down into whatever gear you choose to select. Not only that, but it could prevent you from dropping into a gear too low for certain conditions and overshoot your powerband, or worst, overshoot your rev limiter and blow up your engine. I could calculate optimal shift points since I know how many RPM each gear drops, but I would rather do it according to gear ratio's. More to come I guess? No Im not bored, I just found the need to contribute something useful every once in awhile.
VG auto's
Gear Ratio's
1st = 2.785
2nd = 1.545
3rd = 1.000
4th = 0.695
Reverse = 2.272
Final drive ratio = 3.642
MPH=(5,950rpm X 12.75) / (2.785 X 3.642 X 168)
MPH= 75862.5 / 1704.01896
MPH= 44.52mph@5,950rpm in 1st gear
MPH/1,000rpm= 7.48mph
MPH= 75862.5 / (1.545 X 3.642 X 168)
MPH= 75862.5 / 945.31752
MPH=80.25mph@5,950rpm in 2nd gear
MPH/1,000rpm=13.49mph
MPH=75862.5 / (1.00 X 3.642 X 168)
MPH=75862.5 / 611.856
MPH=123.99mph@5,950rpm in 3rd gear**
MPH/1,000rpm=20.84
MPH=75862.5 / (.695 X 3.642 X 168)
MPH=75862.5 / 425.24
MPH=178.40mph@5,950rpm in 4th gear ***
MPH/1,000rpm=29.98mph
**Does not take into account T/C lock-up
***DOES NOT MEAN YOU CAN REACH THEORETICAL TOP SPEED IN THIS GEAR
For the love of human-kind, don't try this on a public road
Gear Ratio's
1st = 2.785
2nd = 1.545
3rd = 1.000
4th = 0.695
Reverse = 2.272
MPH/1,000rpm=20.84
Originally Posted by mtcookson
what are the gear ratios for the VG 5-speed?
1st= 3.285
2nd= 1.850
3rd= 1.272
4th= 0.954
5th= 0.795
Reverse= 3.429
Final Drive Ratio= 3.650
I worship the person who wrote this page http://www.geocities.com/jgadlage/maxspecs.html
Its hard to find 3rd gen specs
VG 5-speed @ 6,000 rpm:
1st - 38 mph
2nd - 67 mph
3rd - 98 mph
4th - 131 mph
5th - 157 mph
@ 7,000 rpm:
1st - 44 mph
2nd - 79 mph
3rd - 114 mph
4th - 152 mph
5th - 183 mph
60 mph @ 2,300 rpm in 5th
75 mph @ 2,875 rpm in 5th
1st - 38 mph
2nd - 67 mph
3rd - 98 mph
4th - 131 mph
5th - 157 mph
@ 7,000 rpm:
1st - 44 mph
2nd - 79 mph
3rd - 114 mph
4th - 152 mph
5th - 183 mph
well... with just an intake and exhaust mine sure acted like it would top out 5th but i had no idea how fast i was going since i pegged the speedo in 4th and went a bit more, then shifted to 5th and had an extra 1,000 rpm. it kept climbing but so did my heart rate (my stupidity went down though) so i just stopped it there. with the turbo... the thing pulls insanely well in 5th. when passing people i constantly have to keep myself from going well over 100 in just a few seconds. with a bad exhaust leak, ****ty intake and exhaust, and low boost i couldn't imagine fixing all that and having even more power. i can't wait!
(note: said speeds were attempted on a race track)
(note: said speeds were attempt on a race track)
major
hmm, I couldn't try for the life in me to reach 39mph in 1st gear. Indicated, it was about 37mph which would mean 6,100-6,200rpm bumping against the rev limiter. Second gear seems to be pretty darn accurate. I would rather not try out 3rd and 4th gear on public roads
now heres a question
heres the specs for a 2nd gen 5spd
Gear Ratio...............Transaxle Model...RS5F50A
1st 3.285
2nd 1.850
3rd 1.206
4th 0.911
5th 0.740
Rev. 3.428
Final Gear Ratio.......................3.429
Now all of the above is from the factory service manual...1986
do ya think the 5th gear and final drive from a second gen could be swaped into the VEs vlsd RE5F50V
if so it would help with the useless 1st in NA mode and usless 2nd and somtimes 3rd in power mode plus it would lower the 4krpms while crusing at 100mph BS
i alreaddy have the gutts of a 2nd gen 5spd in a box in my basement and 2 spare vlsds that need some attention
1st 3.285
2nd 1.850
3rd 1.206
4th 0.911
5th 0.740
Rev. 3.428
with that 86 gear box you'd have:
1st - 41 mph
2nd - 72 mph
3rd - 110 mph
4th - 146 mph
5th - 179 mph
100 mph would be 3,350 rpm in 5th
60 mph @ 2,000 rpm in 5th
75 mph @ 2,500 rpm in 5th
I think that'd actually hurt mileage a little bit since that's a bit below the peak torque on our engines (VG at least).
To really maximize fuel economy on the VG with that gear box you'd have to do ~84 mph.
1st - 41 mph
2nd - 72 mph
3rd - 110 mph
4th - 146 mph
5th - 179 mph
Apr 16, 2020 05:15 AM
