Instrument panel not lighting
Old Jan 12, 2005 | 10:13 PM
Dj Paul's Avatar
i was wiring my remote start alarm system, and never got it finished, i had the smj disconnected but put everything back. It was a worthless attempt but i am left with absolutely no driving information.
Old Jan 13, 2005 | 05:08 AM
internetautomar's Avatar
mod or sell?
are your tailights working?
check your fuses first.
then fusible links.
then pull everything back apart and look for an incorrect connection.
Old Jan 13, 2005 | 02:42 PM
Dj Paul's Avatar
yes
ya my taillights work fine, everything else is in perfect working condition. The fuses are good and everything.
Old Jan 13, 2005 | 03:50 PM
mod or sell?
then.
I'm not much of diagnose over the phone type guy on stuff I haven't run into yet
Old Jan 13, 2005 | 05:16 PM
Governor's Avatar
undo everything you did one at a time..after each..try your instrument lights..you might narrow it down this way..if they worked before then it was something you did...keep looking you will find it
Old Jan 13, 2005 | 07:16 PM
disgruntled's Avatar
drop the soap box and take a peek inside seriously, you might have crossed a wire somewhere and shorted out your timer control unit, just remove it (its right behind the stock alarm box near the fuse box) its a small, plastic box with a whitish color, open it up and check the back(where the solders are) to see if there is any burnt out track.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
GregL65
Sep 5, 2015 09:37 PM
