power
Old Apr 25, 2001 | 11:41 AM
mymax93's Avatar
how do u use the power switch. i feel absolutely no difference on it. my father used to have a 90 gxe and he said all it did was eat more gas. i have a 93 gxe and i really dont notice ne thing. is there a specific way to use it? when to switch it on, when im in park when im at a light? help?
Old Apr 25, 2001 | 12:12 PM
Soon2BMaxed's Avatar
all the power switch does is make ur tranny shirt at higher revolutions. yes u will get worse gas mileage.
Old Apr 25, 2001 | 12:22 PM
Z-rated's Avatar
obviously you haven't revved your Max high enough to know the difference. You will not feel a difference with normal low RPM driving.
Old Apr 25, 2001 | 12:55 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I think gas milage improves....
on regular driving, but there is no difference in highway miles. thats the conclusion I've heard many of the other guys come up with as well as myself....
Old Apr 25, 2001 | 02:00 PM
mymax93's Avatar
ive pushed her to her limits and there is no difference, ive read somewhere that it might rev 500 rpms high or so, what real difference is that? also ive read that switchin on the comfort is a better idea because it delivers more low end revving
Old Apr 25, 2001 | 02:06 PM
MadMaxBrent's Avatar
Power switch
All it does is change the shift points for the auto. (At least it does on mine) In normal driving it will rev out longer before it shifts up a gear. In hard driving the only difference is it will rev out maybe 500 RPM more before it changes up. The kickdown points also change so the auto is more likely to chop down a gear or too more readily under Power mode.
Brent
Old Apr 25, 2001 | 02:53 PM
mymax93's Avatar
is there any specific time when to set the switch?
Old Apr 25, 2001 | 02:58 PM
Any time
Not that I'm aware of. I've often had the car in the standard position then changed to Power (on hills and passing cars) whilst the car is in motion. Have noticed no ill effects.
Brent.
Old Apr 25, 2001 | 03:01 PM
DA-MAX's Avatar
I leave it on most of the time...
since I usually rev around 4k anyways...might as well so the car won't shift around 3k. bascially if you accelerate faster than normal I guess you can leave it in "P"....
Old Apr 25, 2001 | 03:02 PM
Jesse93GXE's Avatar
I changed my power/comfort setting at any time without any detrimental effect. While parked with the car off, while driving, while idling, while hill climbing..
It just makes the auto tranny more willing to rev to high RPMs and quicker to downshift. In power mode, if I press the pedal about halfway (not soft, not flooring it), the engine will rev a good 1000rpm higher than in normal mode. In the normal mode, to get it to rev high, I usually have to floor it.
Old Apr 25, 2001 | 03:08 PM
DA-MAX's Avatar
The only time I could see probs..
is on a STEEP hill! to me it seems that that would put more stress on the tranny and engine...since you're revving high but only going higher, not straight on a flat surface
Old Apr 29, 2001 | 07:09 AM
Jaybird180's Avatar
The Owner's manual recommends setting it in the center (auto) position. I have noticed that when I set mine to Power, I get a smoother engine. I usually set it to power when I leave the house a few minutes late (and haven't been late to work yet).
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
