Jeff...and others you`all were right.....
I pulled the fuel rail and found that I had damaged two of the injector Insulators
....so that was my problem. Changed the oil and there was probably 1 1/2 gal of gas in the engine
I hope Internetautopar has what I need......
Thanks to all....
Thanks to all....
Wow, was the engine ever running with that much gas in the oil? If so, then your engine is probably spotless
. Hope you didn't ruin any bearings.......................................... .................................................. .......
The first time I ever seated a set of injectors, I found out the following time that I cut one o-ring. Fortunatly it was not enough for it to leak, I got lucky. One thing that should be done when installing injectors is to make sure there is no crud where the injector has to sit. I used acetone and q-tips to clean the rail seats.
hmmm I dont see how the insulators could cause the problem. I know the O rings will because like Jeff said it holds the gas back. The insulators I think is just for the injectors to sit in. I may be way off on this but dont think the insulators are responsible for holding any fuel back.
hmm.... this sounds very, very familiar... oh yeah!
i had one injector seated improperly (first time i took one out and was the only one i took out). the engine actually hydrolocked and wouldn't start... i couldn't figure out what was going on and tried pull starting it... thank God for nissan's strong internals. i'm still amazed that i didn't snap a rod or something. (note: this was when i was still debugging the turbo setup and it had been about 6 months after i started so i was getting very short fused about the whole thing and basically lost any care about what happened to the thing... after finally getting it done i have much more care about it now
when i went to drain the oil, it basically looked like black gasoline coming out. no viscosity whatsoever.
went back and seated it properly and haven't had a problem since.
)when i went to drain the oil, it basically looked like black gasoline coming out. no viscosity whatsoever.
sascuderi
Aug 8, 2009 11:03 AM
MAXIMUS86
Oct 6, 2007 10:24 PM
ROCKART
Sep 25, 2007 09:02 PM
brandnew
Sep 2, 2007 09:34 PM
brandnew
Jun 15, 2007 10:29 AM
