Speaker questions
Old Jan 15, 2005 | 06:36 PM
SteelPython's Avatar
Speaker questions
The next two days i am going to be installing new front and rear speakers.
I have a few questions that i was hoping some of you could address.
I have a 1990 Maxima GXE everything is stock (non-bose).
I got to the rear speakers once before, the stock speakers are two 5" or 5-1/4" clarion speakers.
1 - Could i use 6"x9" speakers in the rear? and if so what modifications if any would i need to do?
2 - If that requires a lot modification could i use 6.5" in the rear? and if so what modifications if any would i need to do?
3 - What are the stock front speakers? and i read in earlier posts that you could fit 6"x9" or 6.5" speakers there. Would making panels similar to this http://www.geocities.com/bracecraig/...eo/stereo.html work as the modification needed?
Thanks on the input in advance
Old Jan 15, 2005 | 07:18 PM
jasba's Avatar
I just replaced my front speakers in my 91 Bose system. I used 6.5" with a speaker plate fabricated from 1/4 plywood. I planned on using 2 pieces of 3/4" mdf sandwiched together like on Craigs page, but I skimped because of time. Mine fit fine, but I will be doing the MDF board later to help angle the speakers. Problem with my 6.5's is that to fit them I had to mount them kinda high in the speaker hole in the door, if I would have built the MDF enclosure it would have allowed them to go lower and angled up towards the driver. Mine sound fine, but I think it could be better. I will try again in the spring though when I can work outside more with warmer weather and better lighting than in my garage....
Old Jan 15, 2005 | 07:32 PM
generation3's Avatar
You should be able to put 6.5 in your rear easy. Doors are normally 4x6 but you can put in 6.5 like jasba said.
Old Jan 15, 2005 | 08:51 PM
AscendantMax's Avatar
if you won't want to make your own 6.5s mounts for the front doors, you can order a set from james92se. he makes some good stuff, and it'll bolt right up. I myself got a pair of his mounts in my doors right now.
Old Jan 15, 2005 | 10:21 PM
Thanks for the input, if need be where would i go about ordering a set? and if you have a chance, what 6.5" speakers would you recommend?
Old Jan 15, 2005 | 11:45 PM
Also i was wondering if the 6.5" bolt in the same way the current 5" or 5-1/4" clarions do?
Old Jan 16, 2005 | 01:44 PM
alien404's Avatar
As far as the rear speakers go I put some 6x9's in a couple of weeks ago (Kenwoods if it matters) had to fold back the metal under the parcel shelf with a pair of tin snips and pliers and cut the flimsy shelf with a strong stanley knife (will be replacing this with mdf later) it was a fairly simple process although remember to cut back (towards the *** of the car) not forwards as the big magnets have a tendancy to latch onto bars connected to the boot.
NB. Australian laws regarding integrity of the shelf (the metal part anyway) are fairly strict and I may need a new shelf when I sell the car but thats a problem for another day.
Old Jan 16, 2005 | 10:23 PM
maxitech's Avatar
Buy some 6x9 boxes, cut them in half (at an angle) with a band saw mount, them over the stock holes, and mount the speakers. I've done this on two different cars and it looks/ sounds great.
Unclejunebug
Apr 2, 2016 05:42 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Socalstillen
Sep 26, 2015 12:01 PM
