relay location help
Old Jan 18, 2005 | 05:57 PM
1991MAXSE's Avatar
relay location help
First I am new to this forum. Hello to all
Now here is my problem I do not have high beams. low beams work fine
when switched to high beam I get no indicator light on the dash.
I have checked the fuses on the fuse panel and at the fuseable link box.
I now want to check for a high beam relay or from looking at a schematic
for the light harness the theft warning relay any help here would be appreciated. oh I did test the switch on the stalk voltage was consistant
also checke voltage at the light plug itself low=fine highbeam 8v drivers side
pass 12.4v thanks in advance jeff
Old Jan 18, 2005 | 06:35 PM
Governor's Avatar
..I assume you checked the bulbs..sorry if I offend u but some dont check simplest things...ok your low beams work so ground is good and 10 amp fuse in fuse panel good...theft relay if so equiped is beside the battery on driver side fender....hmm there aint crap for headlight info in manual. Your gonna have to follow schematic from headlamp and move bacwards checking voltage till u find open circuit..Hope one of the other guys can help you more.. Good luck!
Old Jan 18, 2005 | 06:40 PM
1991MAXSE's Avatar
thanks for the post, yes I checked the bulbs
Old Jan 18, 2005 | 07:46 PM
Governor's Avatar
leave drivers side bulb unplugged and try your high beams...
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
zmcneely13
Sep 26, 2015 02:26 PM
