Key in Door
Old Jan 18, 2005 | 07:26 PM
MarkofCain's Avatar
Key in Door
So it was a chilly winter afternoon and i put my key in the door to unlock it and **SNAP**... it broke off in the key hole, luckily enough i did have spare. I have tried to pry it out with needle nose pliers and a paper clip with sadly no success. Does anybody know of a way I can get the key out of there myself without having to take it to a locksmith and spend $50 for a 3 second job? Thanks!
Old Jan 18, 2005 | 07:37 PM
Governor's Avatar
Tough one!! if you cant get it with a broken key extractor (wire) try a locksmith. I had this once and it is very hard to get out..I used a thin piece of wire with hook bent on end,I threaded it along side broke stub till end and rotated wire so hook caught the end of key and I pulled it out..have to use small screwdriver if broke off past vertical to get it straight up and down again.
Old Jan 18, 2005 | 07:50 PM
tripleGmax's Avatar
make sure you spray in the locks with liquid graphite, your car is friggin 14 years old and that gunk will build up quick. i would spray down the antenna if i were you too with some de-icer lubricant as well. do all the locks. i swear by this stuff, becuase i couldnt get in my doors open and i broke a key, luckily not in it. now my locks open like new after spraying some liquid graphite. the powder graphite isnt much help with car door locks. fyi for anyone with old locks.
good luck getting that out. try a magnet and a wire type deally might work...
Old Jan 18, 2005 | 10:13 PM
Cliff Clavin's Avatar
Way out West
I didn't know it got that cold in Georgia...
If you have some spare time, but not much money, maybe you can take the lock apart and get the piece out. You might have to go at it from inside the door panel. Not sure, though as I have never done this before.
Old Jan 19, 2005 | 02:29 AM
Wiking's Avatar
Thats the way if the good advices given above do not work out. (Trying them, flood, soak the lock liberally.) Then its easy to drill a angled hole with dremel in the end bit of the key, fit a needle in for extraction.
Old Jan 19, 2005 | 06:14 AM
internetautomar's Avatar
mod or sell?
shave the locks!
Old Jan 19, 2005 | 06:24 AM
bhunter's Avatar
The magnet deal was suggested before on a similar post here a couple months ago. Keys are brass, not steel. This will not work. Everyone who thinks their keys are steel--try to pick one up with a magnet.
Try using a dental pick to get the broken key out. You can usually buy one at a locksmith's --gee I wonder why?
Old Jan 20, 2005 | 12:19 AM
jwmaxse's Avatar
I just had to do this on my 200sx. I ended up just taking the door apart and taking the lock off the door, it's much easier when it's off the car and you can push the key from the other side of the lock. It took me less than an hour to do the whole thing, maybe only 30 minutes. So hey, if you want to drive to Illinois then I'd gladly charge you $49.95 and do it for you, that is cheaper than a locksmith
Old Jan 20, 2005 | 12:45 AM
rrrfoma's Avatar
I agree. Take door apart on the weekend. It shouldn't take long.
If I remember correctly, it took me 2h to take everything apart AND to rebuild power locks actuator. Just be carefull with plastic clips.
Old Jan 20, 2005 | 06:08 AM
tripleGmax's Avatar
My bad, i didnt realize that.
brass monkeys.
Old Jan 20, 2005 | 08:41 AM
mod or sell?
brass monkeys.
Beastie BOOYYZZZ
Old Jan 20, 2005 | 08:42 AM
tripleGmax's Avatar
Beastie BOOYYZZZ
that funky monkey!
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
