Got Clutch?
Old Jan 19, 2005 | 03:15 PM
america8371's Avatar
Got Clutch?
When I get up in the morning to go to work I go to my car to find that my clutch petal is sunk to the floor and I can't put it into 1st. I have to lift it up with my foot and then it would start working again. I checked my slave cylinder hoping that the problem was that the slave cylinder was leaking (beacuse they're only $20.00 around here). But it wasn't leaking. What could be the problem.
Old Jan 19, 2005 | 03:18 PM
Jeff92se's Avatar
I'm needing a caw
Master cylinder? Mine did the same and it was the slave though. It didn't look like it was leaking but once I peeled back the little rubber boot, it would gush out. If your fluid is okay and there is not leak in the lines, it's the slave. But I changed the SC and MC anyway. I already changed my line to a SS unit already.
Old Jan 19, 2005 | 06:12 PM
alpicone's Avatar
I had the same problem in my car. It was the MC. Both the SC and MC are cheap so either way it isnt too bad and they are both easy to replace.
Old Jan 19, 2005 | 06:35 PM
«§»Craig B«§»'s Avatar
probably master cylinder
I know awsm66 had the exact problem on his car and the MC fixed it. It would fall to the floor the first time but then be ok after bringing it back up
Old Jan 20, 2005 | 01:56 PM
ChrisCheezer's Avatar
yeah same problem the guy had that i got my car off of, he replaced the mc and fixed it.
goodluck
Old Jan 20, 2005 | 02:09 PM
oh, so let me get this straight. it's the master cylinder, not the slave cylinder?
Old Jan 20, 2005 | 02:16 PM
alpicone's Avatar
Check to see if it is the SC. It is easy to see if it is leaking you would see the fluid around/on it. In my case it was the MC, I didnt see any leaks around the MC either but it ended up being the problem. $30 for the part and 15-20 minutes to replace. Just make sure to compare the lengths of the rod and dont get any brake fluid on your paint.
Old Jan 20, 2005 | 02:58 PM
subs1000w's Avatar
ill make this really easy for you since it sounds like you dont have to knoledge to diagnose the problem
JUST REPLACE BOTH
you can get BOTH OF THEM for under 50$ at any autozone
if you do that you wont have to worry about them for a long time
im speaking from experiance because ive reaplce both on my car and on my friends that we did the swap on and im kicking myself for not doing them both at the same time because its stupid to be inconvienenced twice
Old Jan 20, 2005 | 05:44 PM
Slamnasty's Avatar
Ah great, now you guys have me biting my nails!
Old Jan 20, 2005 | 05:46 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
the MC isnt really that hard to change, ive done it before and succeded first shot
Old Jan 20, 2005 | 05:50 PM
Jeff92se's Avatar
I'm needing a caw
Just replace the MC SC and the line. Might cost a bit more but it's worth the peace of mind. Hell they lasted 2,00000000000 miles so far right?
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
