Fuel Pressure Riser?
fuel pump wouldn't change anything except for potential. larger injectors would make it run very rich causing it to also lose a lot of power. i know with even 259 cc injectors (stock is 180 cc) the car will barely run with an unmodified ecu.
So even if I get a JWT ECU, and tell them to incorporate the modifications necessary to take advantage of an upgraded fuel delivery system. To simply upgrade the fuel system wouldn't do anything practically, unless I'm pushing alot more power.
correct. i don't believe you'd even need any fuel upgrades for anything jwt can do ecu wise. once you start getting into forced induction, nitrous, or even going high compression then it starts to change. (although you having a VE already it would take some custom made pistons to go any high compression and whatnot).
basically, you're fuel system is fine at the moment.
both would, but the TT pistons would be better. the VG30E pistons would fit but you'd have to use the VG30E rods and both of those would be a downgrade of what you already have. the VE already has the TT rods basically so you could slap on some higher compression VG30DE pistons or some lower compression VG30DETT pistons for some boost.
you couldn't let me answer
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
