shock/strut question
Old Jan 24, 2005 | 08:23 AM
Orbit82's Avatar
I drive a 92 SE. It handles like crap, lots of what i guess to be body roll/pitch. Basicly when going around curves it feels as though i could easily loose control of the car, dosn't feel stable, even when driving at a moderate speed. Took it to the local Nissan dealership and they said i need new struts, "all the fluid is gone". So here's the question(s). Shock, Strut, are they the same thing? I want new ones but i dont know exactly where is the best place to get them, and which ones to get. I understand 'gas' filled are better than 'fluid' filled. I want some that will not only restore the orginal handling, but go slightly better. i'm not saying i want to spend a ton of money and buy racing autocross stuff, i just want some decent ones and i dont want to buy them from Nissan. So please help me understand what to get and where. THANKS
Old Jan 24, 2005 | 08:52 AM
Wiking's Avatar
Its shocking where this line is drawn: strut-shock...
Google: 50-80$ depending where u buy. I did use nissan bluebirds shock cartridges at rear because ½ price here, (needs one extra spacer), stanzas cartridges will work also.
On cold days gas shocks work better from beginning.
Old Jan 24, 2005 | 09:01 AM
internetautomar's Avatar
mod or sell?
all struts have some oil in them.
and for just a set of stock replacements I'd suggest KYBs, which I sell at a reasonable price.
they will be better than stock in terms of ride , handling and braking.
Shocks and struts perform the same function, but they are not the same thing. however they are used interchangably
Old Jan 24, 2005 | 09:09 AM
Bman's Avatar
KYB replacements are usually the choice for low cost, mild upgrades if you don't want "normal" replacement shock absorbers. Check internetautomar's page for some prices and options.
The whole assemblies are "struts", and the thingies inside them are still "shocks" (shock absorbers).
Old Jan 24, 2005 | 09:30 AM
wolfpack_5150's Avatar
Apple Pie Monster
I would agree so far with the rest about the kyb.....I suggest replacing your strut mounts, and dust boots too...Also you may want to think about a new set of springs. They are only around 200.00 and will help you out with the body roll, nose dives...just dont get an extreme drop with kybs.
Of course the best setup we can buy are konis,you'll pay out the nose but I think they are well worth it.
Old Jan 24, 2005 | 09:32 AM
Governor's Avatar
My struts were worn completely out and never affected how the car steered..did they check the tire rod ends??? I replaced my struts and I didnt feel any difference in how the car handled.Oh and your struts are your shocks..they are mounted inside the coil springs.
Old Jan 24, 2005 | 10:15 AM
Wiking's Avatar
And I have a two stroke engine maxima...
Old Jan 24, 2005 | 04:05 PM
Governor's Avatar
I never heard of that before..hows it run???? MY STRUTS WOULDN'T EVEN STAY UP OUT OF THE CAR!! I PUT NEW ONES IN AND FELT NO DIFFERENCE(FRONT ONES ONLY) IN HOW THE CAR STEERED!!!!
Old Jan 24, 2005 | 06:41 PM
mod or sell?
did you prime the struts before installation?
Old Jan 24, 2005 | 07:36 PM
Governor's Avatar
yeah..I loosened the bleeder screw and bled them
Old Jan 24, 2005 | 07:52 PM
«§»Craig B«§»'s Avatar
I think what internetautomart meant was did you refill the rear struts with oil like you're supposed to?
Old Jan 25, 2005 | 12:36 AM
Wiking's Avatar
Most people like dry installation. And wonder...
Old Jan 25, 2005 | 06:42 AM
mod or sell?
actually I was refering to holding the strut up right and compressing the strut and letting it go back up (pull it back up if neccessary) a few times until it comes back up fully by itself.
when struts are stocked they are normally stocked on their side so some fluid will go past the piston you need to get all the fluid back on the side it belongs, hence the priming I'm refering too.
and on the rears you need to add fluid to the housing where the cartridge goes.
Old Jan 25, 2005 | 07:29 AM
Wiking's Avatar
I bet most shops install them dry, why bother hehe? Nobody knows the difference, there proof stands on this page... I had to fight (?) once I went to a shop for installation: "weelll, we have never added oil..." - I had to insist: ...on my car u do!
Old Jan 25, 2005 | 08:49 AM
Governor's Avatar
I never knew you had to do that..mine were gas struts but I guess there is oil in all of them?..I never changed the back ones yet but thanks for the tip cause I will be replacing them this spring.
Old Jan 25, 2005 | 09:16 AM
mod or sell?
it's not 100% neccessary and most shops won't do it.
because it eventaully does it itself.
it's just something to be done to make sure it all works correctly before install.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
