vaccume hose size and speed bleeder size
I am looking for the size of the vaccume hose that is atached to the brake booster and the engine.
(I am trying to fix the old brake goes to floor the first time then has pressure the 2nd time)
the manual said if the vacume hose is leaking it can cause many weird problems. the hose on the car now is solid a a rock and 15 years old, so I want to replace it any one know what size it is?
I am looking for the thread size of speed bleeders, I have the on my motorcycle and thought they may work on the bar also....anyone?
I am also looking for the size of the heaterhose that goes into the firewall for the heater core, I want to flush out the heater core and I read that those hoses are a ***** to remove and they should be sliced off...
(I am trying to fix the old brake goes to floor the first time then has pressure the 2nd time)...
Vacuum -works for you- as a booster. If no vacuum, only harder to halt the car.
Pedal flooring is smtg else, fluid loss or air in the system. And there has to be a worse, rotten reason for those leaks. Check out.
U have those hoses, measure.
Originally Posted by Governor
AND I HAVE A 3 STROKE MAXIMA! TAKE SOME ENGLISH CLASS'S...
he's from Sweden so his English isn't perfect, but you can get the meaning of it. Also, CLASS'S isn't the word you're looking for there slugger
Quite soon its u 3 S heart, with the block letters u utilize. Sorry damsels, u with only one language. How about 5?
