PS Pressure host replacement
Old Jan 25, 2005 | 03:02 PM
Schwagoo's Avatar
the hose is like 36 bucks at Autozone... how hard is the replacement of this piece?
any good write-ups on it?
90 SE 5SP
Thanks!
Brian
Old Jan 25, 2005 | 03:59 PM
GRNMAXDMON's Avatar
just look at it ur old one its difficult. it took me about 20 min. or so to change mine. i haven't seen a write-up on this but its not hard.
Old Jan 25, 2005 | 04:02 PM
spyhunter84's Avatar
yea its pretty simple but the only hard thing is breaking loose the bolts that hold the hose in place
Old Jan 25, 2005 | 04:03 PM
aminus21's Avatar
not hard. just 2 bolts.. i think 22mm, the bottom one is a little harder to get to.
Old Jan 25, 2005 | 04:38 PM
Schwagoo's Avatar
COol... yea it looks like the hardest part is getting to that bottom bolt section.
is there any special way to fill the thing back up with PS fluid, or just fill the resevoir a few times?
Old Jan 25, 2005 | 04:43 PM
jasba's Avatar
Mine was a little bit of a pain, just did it a few weeks ago. Biggest problem was removing the bottom bolt. I had to cut a 15/16 th's wrench down to about 5" long to get to it and have enough range of motion to turn it. Other than that it was easy though.
Old Jan 25, 2005 | 05:13 PM
GRNMAXDMON's Avatar
just refill the resevoir
Old Jan 26, 2005 | 09:29 AM
Bman's Avatar
I'd recommend trying to fit a long-ish breaker bar for the bottom one, as it can be stubborn. Pan recommended as it will run out. When installing try not to let it touch any exhaust manifolds if it comes close.
Proper bleeding procedure is with the wheels off the ground. Start the engine and don't let the reservoir run dry as you turn the wheel lock to lock a few times. That's it.
Old Jan 26, 2005 | 12:38 PM
bhunter's Avatar
The only thing I could add is when you put the new hose on attach the lower end first. You have to twist it a little to get the hole lined up and it is easier to twist the top one with the lower one attached that the other way around.
hydriplex
Aug 28, 2015 02:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
scarletsosa
Aug 17, 2015 09:09 PM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
