will these rims fit?
Old Apr 27, 2001 | 01:04 AM
ngthing's Avatar
offset: +42
bolt pattern: 4-100 & 4-4.5
back setting: 5 5/8
Old Apr 27, 2001 | 01:06 AM
Weasel's Avatar
No, Maxes have a 5*4.5 (5*114.3) bolt pattern.
Old Apr 27, 2001 | 01:25 AM
ngthing's Avatar
i was a bit scared for a sec, then I saw some other variations...so, 5-100 & 5-4.5 should work
Old Apr 27, 2001 | 09:06 AM
Jeff92se's Avatar
I'm needing a caw
That's getting a little high for a 3-gen(offset-wise). Depends on how wide the rim is and how wide a tire you use. I could rub the inside strut.
Old Apr 27, 2001 | 03:19 PM
ngthing's Avatar
It's 18x7 and the tires are the Nitto 555s, I think 235/40/18 or something like that.
Old Apr 27, 2001 | 03:33 PM
Jeff92se's Avatar
I'm needing a caw
Well compare to this. the 16" z rims that people use on 3-gens are 45-46mm offset and are about7" wide. With 225-50 sized tires, it rubs the rear strut tower and is fine in the front. So 3mm less offset on yours but 10mm more width on the tire. I think it will rub. But you can try them out before buying?
Old Apr 27, 2001 | 03:38 PM
ngthing's Avatar
I checked my notes, and I wrote down:
225/40-18 and 215/40-18
...so i'm not sure what size tires I will be gettin
Old Apr 28, 2001 | 04:36 PM
MILLENIUM MAX
Well it sounds like you may need atleast 3mm spacers for the rear ngthing to prevent the rubing and make the wheels look flush with the fender.
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
