doors misaligned?
Old Jan 25, 2005 | 09:48 PM
Hectic's Avatar
doors misaligned?
luckilly i don't have this problem with my maxima (yet) but i have seen many with the problem of the door(s) sagging which causes friction when closing it. if you've had the problem then you know what i'm talking about. it seems to affect a lot of 3rd gens. hopefully it's just loose hinge bolts. anyone had the problem and corrected it? i totalled the last max before i could fix it.
Old Jan 25, 2005 | 10:39 PM
Minty91GXE's Avatar
i just used a nickle under the bolt plate of the door's hinge, reachable from the inner side of the door when opened. just loosen the bolts enough to slip the nickel under the hinge. you will want to use a jackstand with a t-shirt or rag on it to hold the door up (as in support, not lift).
took 10 min., 3 months later, still perfect... probably will stay that way a long time.
t
Old Jan 25, 2005 | 10:52 PM
Hectic's Avatar
sure it couldn't have been fixed by tightening the top bolt? if not, where's the fault?
Old Jan 25, 2005 | 11:02 PM
Wiking's Avatar
The hinge pin is one of the Maxima places of mfg cost cutting... Quite a pain to change. Penny -plan is lot easier.
Old Jan 26, 2005 | 04:11 AM
bhunter's Avatar
Several months ago someone suggested about the same thing. Take the two bottom bolts out, slide the necessary number of washers in there and replace the bolts. Door shuts like a dream. You could get new hinges but the fender has to come off to replace them.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
