9007 vs. 9004 pics
Old Jan 26, 2005 | 07:25 PM
Loe max's Avatar
9007 vs. 9004 pics
I used my dads Maxima as a comparision against the garage wall.
Here is the low beam comparison:
Here is the highbeam comparison:
This is using Sylvania standard non colored 55/65watt bulbs for the 9007 bulb. The 9004 equipped car used a similar bulb (45/64watt)
Old Jan 26, 2005 | 07:43 PM
Cheocwa's Avatar
You should probably get silver stars
Old Jan 26, 2005 | 07:52 PM
AscendantMax's Avatar
nice comparison shots...much more output on the 9007s.
Old Jan 26, 2005 | 08:01 PM
MrGone's Avatar
i really should, but ugh
Old Jan 26, 2005 | 08:28 PM
Michael's Avatar
Back in a 3rd Gen.
I did this a couple of weeks ago and love it. I used cool blues because they are whiter than stock but a lot cheaper than silverstars.
Only problem now is I have some projectors coming so its all for naught...well not actually because I am going to take my time and do the projectors similar to how I did my old BMW lights so I dont have to be in a rush since I have the 9007s in. I will seal them this time though.
Old Jan 26, 2005 | 09:11 PM
Slamnasty's Avatar
Wow. Big diff.
Old Jan 26, 2005 | 09:54 PM
aminus21's Avatar
nice..is there a writeup?
Old Jan 27, 2005 | 03:52 PM
Eric95se's Avatar
do you need to splice in the higher power harnesses with the light upgrade (like on the 4th gen?) or did you just directly swap out the headlights?
Old Jan 27, 2005 | 03:55 PM
fred's Avatar
how much do the bulbs cost?
Old Jan 27, 2005 | 04:51 PM
ghostmax's Avatar
the 9007 xtravision cost $10. you splice the ground and the low wires. if you rotate the bulb so that the high beam is lower on the ground than the low beam, you can splice the low and high beams so that the signal stalk is not pushed forward (and the high beam indicator is not on). in this way, your high beam 65w will actually be the low beam and vice versa. hope that's clear.
Old Jan 28, 2005 | 06:51 PM
Loe max's Avatar
yep, thats just about it actually.
Old Jan 28, 2005 | 08:44 PM
RA030726's Avatar
I'm nutty for Nissans
sweet! where can I get these?
Old Jan 31, 2005 | 06:59 PM
Loe max's Avatar
Some crazy guy did the write-up. Who knew what condition he was in when he wrote it
Old Feb 5, 2005 | 09:15 AM
evoMaxi
Check out MotionR 6000k. They outperform Silverstar, Sylvania/osram, PIAA, Phillips and more.
http://www.motionr.com
Testimonials:
http://hyundaiperformance.com/forums/topic.php?t=8938
http://www.cardomain.com/member_page...page_id=374204
http://www.toyotanation.com/forum/sh...threadid=19415
http://www.sonataspeed.com/yabbse/in...17225#msg17225
http://www.j-body.org/forums/read.ph...07861&t=207861
http://www.topendmotorsports.com/mem...searchid=11937
http://www.toyotanation.com/forum/ar...c/19071-1.html
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
