weird problem with the max
Old Jan 27, 2005 | 11:17 AM
whitemax28's Avatar
need some help on this guys. When I turn they key to start the car, nothing will happen. I do not hear the starter or anything. Its not the battery because all the lights turn on and the seatbelts go on and everything. Funny thing is this has happened before and now its happening more frequently. It would not start in park but when I manually shifted the shifter into neutral and attempted to start the car and it started. What's going on??? Anybody have this problem??? Help!!!
Old Jan 27, 2005 | 11:59 AM
MAXI's Avatar
I'd say starter problem.
Old Jan 27, 2005 | 12:19 PM
Greeny's Avatar
¯\(°_o)/¯
It might be the neutral start switch...
http://www.partsamerica.com/PPF/Sour.../PartTypes.asp
Old Jan 27, 2005 | 02:17 PM
fred's Avatar
probably your safety switch deal so you wont start it in gear, but i dont think it is the neutral swich, cause it starts in nuetral?
i dunno
Old Jan 27, 2005 | 02:54 PM
DennisMik's Avatar
The neutral starter switch is probably bad. They are like 2 switches in one, so the section for the park position can go bad and still work in neutral.
Old Jan 27, 2005 | 03:38 PM
fred's Avatar
ah ha, thanks for explaining how that works...
Old Jan 28, 2005 | 12:29 AM
kcidmil's Avatar
I'd agree, easy way to tell. Tap on the starter, and try again. I'd bet that it'll start. Your brushes are starting to wear.
You have two options at this point.
1. You can have it rebuilt, around $45 to have new brushes installed
2. Go get a lifetime warranty starter from Napa or other parts place. So when this happens again, you bring it in and get another. Cost around $180.
Old Jan 28, 2005 | 03:33 AM
Wiking's Avatar
Originally Posted by whitemax28
...not start in park but when I manually shifted the shifter into neutral and attempted to start the car and it started.
Your Park -position is not really fully in park position - if the fault statement contains all... The sw/and or lever needs adjustment.
Old Jan 28, 2005 | 03:19 PM
keener's Avatar
had the same problem, but when i turned the fan and radio off the car would start. the battery volts were low so i replaced it and everything was fine for about a week. then the problem resurfaced. I changed the alternator and everything is normal. considering your car starts in neutral i am guessing a switch may be bad. good luck.
Old Jan 28, 2005 | 03:36 PM
MAXI's Avatar
sorry, i did not see that "move to neutral it starts" line there. yes, its probably the start switch. i had to push mye shifter all the way in park just to get the car started.
Old Jan 29, 2005 | 01:39 AM
Wiking's Avatar
Sounds like alt grounding had been floating. Add a grounding wire between alt shroud and chassis/or engine to keep them running. The old engine block & alt supports oxidize and stop conducting electricity ruining voltage regulator and battery.
see http://www.cardomain.com/memberpage/748507/10
matts95max
Apr 23, 2025 10:44 AM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
