Max Smoking Badly -BLACK
Old Jan 28, 2005 | 05:53 AM
liquidsnow's Avatar
Im thinking it's the o2 sensor, but I would like to scan it to find out what's really going on because the engine light came on. no one around here has the scanner for this car. does anyone know what type of scanner I can buy some where?
Old Jan 28, 2005 | 06:54 AM
internetautomar's Avatar
mod or sell?
look up in the stickies for how to pull codes.
no scanner needed
Old Jan 28, 2005 | 07:20 AM
Turk's Avatar
Sounds like its burning to rich. Does it smell like gas? If its blue your burning oil.
Old Jan 30, 2005 | 07:56 AM
liquidsnow's Avatar
smells like gas.. black as hell wastes a **** load of fuel.. I cant get the ecu to give me the code I tried the screw thing.. doesnt give me anything..
Old Jan 30, 2005 | 08:03 AM
mod or sell?
then you got a serious problem.
has any work been done recently?
Old Jan 30, 2005 | 08:17 AM
PulsarDriver's Avatar
Really really really really dirty filter?
Its running super duper rich to have that much black smoke O_o MAF or O2?
Old Jan 31, 2005 | 07:14 PM
james93gxe's Avatar
This sounds alot like what happened when my ecu died. It would foul plugs, run rich, black smoke, and sometimes stall. My mechanic said it wouldn't go into closed loop and the ecu wouldn't give codes. Had the ecu rebuilt and it fixed everything.
Old Feb 1, 2005 | 08:58 AM
holiday's Avatar
Hey james93gxe im having the same probs you listed. Are there anyways i can test my ecu myself? Also how much did it cost you to get your ecu rebuilt? Is it just better to buy a used or new one?
Has anyone else had this problem?
Old Feb 1, 2005 | 10:16 AM
Wiking's Avatar
Had intermittent blk smoke; TPS was bad. Maybe not as bad as u did. Documented what I did, been working wel since (somewhat high fuel consumption). Just ! today after knock sensor resistor bypass got 30mpg, so now its almost as new (...but tranny lock)...
see: http://www.cardomain.com/memberpage/748507/1
Old Feb 1, 2005 | 03:14 PM
holiday's Avatar
Wiking thanks for the info. When you had smoke did you also have idle problems. Also did your ecu throw any codes.
Old Feb 2, 2005 | 03:01 AM
Wiking's Avatar
Idle floating around 900-1300. No codes ever. Btw, I did not actually see the smoke, friends driving behind (cold engine) complained to me, I complained at the gas station...
I did not get 'any' help from crap chilton manual, thereby I went through the whole car, and documented what I found, corrected. Thanks to this forum's super men, I later made a collection of the documents to this http://www.cardomain.com/memberpage/748507/1 ... Now after 0.5mOhm resistor 'KS bypass surgery' got 30mpg [higway 60mph] first time ever (after 1˝yrs).
ECU is a 50 code lottery machine trying to throw dice for the 5000 possible ol' car problems...
Old Feb 3, 2005 | 07:57 PM
james93gxe's Avatar
Sorry for the late response. No, I couldn't get anything out of my ECU. Even with a Snap On scanner. I think its cheaper if you can find one at a junk yard, make sure the numers on the ECU match. It cost me 250 for a rebuild with a warranty.
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
