Those VEer's using the Yota filter. What have you
Old Jan 31, 2005 | 12:49 PM
Jeff92se's Avatar
I'm needing a caw
been using to remove it? Seems to be a non-std size. I've used everything but the kitchen sink to remove mine. Last time I had a strap wrench sitting here. Worked well. And you?
Old Jan 31, 2005 | 12:59 PM
HTPerformance's Avatar
used a c-clamp scrunch it down and rotate.
Old Jan 31, 2005 | 01:01 PM
Jeff92se's Avatar
I'm needing a caw
That's just a bit to ghetto for me.(I'm not sure if that would even work) I suppose someone will chime in with "stab the filter with a long screwdriver and twist" too. hehe
Old Jan 31, 2005 | 01:04 PM
We used that method on a factory Subaru WRX first oil filter on the engine, the thing was on there, stupid assembly line robots scrunch them on there. It worked.
B
Cliff Clavin's Avatar
Way out West
I went to Fred Meyer and bought the smallest filter wrench they had (the smooth clamp down kind). I checked to see if it would fit by taking one out of the package and testing it on a Purolator filter that cross referenced the Toyota one.
Someone put the first one on pretty damn tight *cough* Jeff *cough*
Old Jan 31, 2005 | 01:07 PM
Jeff92se's Avatar
I'm needing a caw
I think I'll just use the strap wrench but it would be nice to find a cup type with a hole for a 3/8" drive or something. That way you don't have to mess with the shields too much
Hey, better than the thing falling off and rolling down I-5 near Portland!
Old Jan 31, 2005 | 01:08 PM
subs1000w's Avatar
thats EXACTLY what i did last time
that what my grandpa taught me so i use it
Old Jan 31, 2005 | 01:10 PM
very functional.... and it protects your tools too by lubing them up...
B
Old Jan 31, 2005 | 01:14 PM
bhunter's Avatar
I use a filter wrench that looks like a big pair of channel-lock pliers that has a big set of rounded jaws. They will take off any size filter.
Old Jan 31, 2005 | 02:06 PM
Ninty-two-se's Avatar
pipe wrench... or the screw driver... cant ever get the strap wrench to work cuz it gets all oiled up when picking it up with oil on the hands..
Old Jan 31, 2005 | 02:27 PM
Mizeree_X's Avatar
Getting back to his roots
My bare hands.....you are only supposed to turn it 1/2-3/4 turns after you hit the resistance. I just changed my oil, I'm on my 4th 'Yota filter, and I removed all by hand and there were no signs of leakage on any of the 3 old ones. Tsk tsk.
Old Jan 31, 2005 | 02:49 PM
MrGone's Avatar
my hands you women
and substitute Yota with Napa
sometimes that whole screw driver trick just acts like a can opener. you can always tie a rag around the filter, put the screw driver under it, twist the screw driver a few times to tighten the rag, then twist. It's a trick I picked up somewhere, have never had to do it though
Old Jan 31, 2005 | 02:50 PM
That'd get the rag all oily....
Old Jan 31, 2005 | 02:56 PM
KLoWnPR109's Avatar
I use Paul Power. It's enough to rip the block in half w/ my bare hands, so taking off filters is a piece of cake
Old Jan 31, 2005 | 03:17 PM
Michael's Avatar
Back in a 3rd Gen.
havent done it yet but I usually take mine off by hand because I dont overtighten them...or I am just super strong one
I do have a pair of pliers that have rounded jaws that I use if I cant get filters off. I also have a huge set of chanel locks I use for big filters that I cant get off.
Old Jan 31, 2005 | 03:43 PM
Bman's Avatar
Hmm... that reminds me - I'm due for a filter change!
I recently bought a pair of large filter pliers with teeth in it (it was cheap), but I've only run into one filter where I've ever had so much trouble taking it off I've had to resort to using tools, so hopefully I'll never have to use them. My last filter came close though, as I pulled a muscle and hurt my hands twisting it so hard. Oops!
Old Jan 31, 2005 | 04:08 PM
internetautomar's Avatar
mod or sell?
Damn I was gonna say that
Old Jan 31, 2005 | 04:18 PM
Aaron92SE's Avatar
NWP Engineering.com
I have a nice pair of jagged teeth oil filter wrench from Sears. It works great. But one time, I didn't have that tool, so I used my leather belt and it worked just fine. I always tighten the filter by hand, but somehow, it always siezes during the 3K mile period.
Old Jan 31, 2005 | 04:24 PM
MrGone's Avatar
There has to be a way to use bailing wire to get the filter off!
Old Jan 31, 2005 | 05:01 PM
My problem is usually the filter is too slippery to get a grip on... So I have to get the wrench out just to grip the thing.
Old Jan 31, 2005 | 05:34 PM
DanNY's Avatar
Ad·min·is·tra·tor
http://www.lislecorp.com/tool_detail.cfm?detail=1051
this saves me many many times w/ smaller filters.
Old Feb 1, 2005 | 01:04 AM
lophix's Avatar
walmart has a small filter wrench (3/8" drive hole) for like $3 or so...that's what i use. Problem is getting it off the damn filter once it's off.
Old Feb 1, 2005 | 05:54 AM
Brad92SE's Avatar
That looks like a damn handy tool! I just use a huge pair of channel lock pliers. My filter wrench might be able to fit onto the filter, but there is no way I can turn it due to lack of room.
Old Feb 1, 2005 | 06:35 AM
DanNY's Avatar
Ad·min·is·tra·tor
yup...i have a few filter wrenches (do a lot of oil changes for various cars) and this one is great when there's no room to move the strap. i mean u can always get the snug fit caps but then you'll need to get so many of them to fit all the different kinds.
all u have to do is place this filter wrench on and stick your 3/8 rachet on and off it goes. it'll never lose its grip because the harder you turn the harder it grips on the filter.
Old Feb 1, 2005 | 07:02 AM
Matt93SE's Avatar
STFU n00b!
you shouldn't ever screw the damn filter on that tight to begin with, but when you do, I just use a big pair of channel locks to remove it. plenty of room on the VE and VG, but there's not so much room on the wife's Alty.. you actually have to stick your hand through the hole in the fender for the steering rack and pull it out that way. it's a PITA.
Old Feb 1, 2005 | 07:05 AM
Jeff92se's Avatar
I'm needing a caw
I have one of those. The Yota is too small even for that one.
Old Feb 1, 2005 | 08:06 AM
cardana24's Avatar
Blown
ok I dont have a third gen, but I like taking my filter off while everything is still hot. I use one work glove for burn protection, then I put a laytex glove on over top of the work glove for grip on the filter (allows you to get a really good grip) then just twist it off by hand....works well for me.
Old Feb 1, 2005 | 08:12 AM
DanNY's Avatar
Ad·min·is·tra·tor
try a newer civic...the damn filter is on the f-wall side middle of the block.
Old Feb 1, 2005 | 08:13 AM
DanNY's Avatar
Ad·min·is·tra·tor
holy jeebus...that's a small filter then. u sure it's not for a motorcycle or something?
they make that filter wrench in 2 sizes...you have the smaller one right?
Old Feb 1, 2005 | 08:15 AM
Jeff92se's Avatar
I'm needing a caw
I use a thick rubber glove. Works great. Thick and is grippy. Oil just wipes off.
Old Feb 1, 2005 | 08:33 AM
dmontzsta's Avatar
Ford Only.
I get under there and get really pissed and frustrated, cus at it a few times, but usually seem to get it off by hand.
Old Feb 1, 2005 | 08:37 AM
cardana24's Avatar
Blown
Try a second gen maxima....same thing
Old Feb 1, 2005 | 08:39 AM
blacks92seAuto
I use my bare hands too....as long as you tighten it properly, like he said, 1/2-3/4 a turn after it hits resistance......It is alot easier to take the filter off when the car is warm too.....if you screwed up when you put the filter on and tightened it way too much, then like jeff said was ghetto....jab a screwdriver in, and pry it free....whats the worst that could happen? youll get oil on yourself...screwdriver....whipdeedooda
Old Feb 1, 2005 | 09:24 AM
DanNY's Avatar
Ad·min·is·tra·tor
can u reach it from the top? because on the civic there's a intake manifold that's blocking access from the top.
Old Feb 1, 2005 | 09:42 AM
PulsarDriver's Avatar
My Camry uses that YZZA2 filter. Getting it off is a big *****, due to location (its right up front, but way too close to hot exhaust manifolds and stuff) and tiny filter size
I just yank it off by hand. If I can't get a grip, I'll wrap one of my leather work gloves around it and twist. Usually gets it.
Old Feb 1, 2005 | 10:17 AM
Matt93SE's Avatar
STFU n00b!
that's where the Alty is as well.. the best part is it's at an angle, and you can't stick your arm in there and see the filter at the same time.. so you just have to keep spinning and wobbling until it catches. ugh.
Old Feb 1, 2005 | 10:25 AM
cardana24's Avatar
Blown
yeah you can reach it from the top but a lot of guys drop it from the bottom.
Old Feb 1, 2005 | 10:29 AM
Jeff92se's Avatar
I'm needing a caw
make no mistake, that is a quality filter. You want a bigger filter? Try a Fram
Old Feb 1, 2005 | 11:47 AM
I wasn't complaining about its small size in relation to its oil-fitering capabilities
but rather its teeny size makes it hard to remove!
Which is why I like the filters my VG and Pulsar use (same one) Nice and big so my big ol hands can get a grip on em!
Old Feb 1, 2005 | 01:00 PM
Jon91SE's Avatar
Pusssseeeehhhh
Use your hand you
