Which manual tranny can I use for a swap?
Old Feb 1, 2005 | 10:44 PM
mrkanda's Avatar
Taking my Maxima to the Max!
Hello,
Once I get to it, I would like to do a Manual tranny swap. Only thing is I have a 1989 GXE Auto and heard that the manual that goes with the '89 VGs is weak. Is there a better tranny I can use, maybe from the later model year VGs ('91-'94)? What about using a 5spd from a different gen (4th, 5th), or better yet, a 6spd from a 5.5 or 6th gen? Also, would I be able to add a VLSD or Quaif? Thanks.
-Mrkanda
Old Feb 2, 2005 | 06:36 AM
internetautomar's Avatar
mod or sell?
donate and search
Old Feb 2, 2005 | 09:36 AM
mrkanda's Avatar
Would love to donate, but honestly, I don't have the $ at the moment. I will as soon as I can. If someone can send me a link to the necessary thread I will certainly read up on it. I haven't seen a specifically relevant thread though in the last few pages. Thanks for any help in advance.
BTW, is there anyone local to me here. I'm in College Park, MD near Washington, DC.
-Mrkanda
Old Feb 2, 2005 | 09:51 AM
mod or sell?
the only easy/direct swap is from an 89-91 SE.
the 92-94 SE will work but you'll need to swap the axles and hubs as well.
Old Feb 2, 2005 | 12:34 PM
subs1000w's Avatar
the trans from the 89-91s are pretty strong if your at the stock HP with a stock clutch on strweet tires youll proboly never break it
the 92-94s have LSD from the factory so if you want that get one of those but like stated above you need the axles and hub from a 92-94 5spd car also
the 95+ trans have a different bellhousing bolt pattern so your outa luck there unless you want to cut the belhousing off a 3rd gen trans and weld it onto the 95+ trans
the front input bearing in the trans is the only weak point so you might want to think about replacing it befor installing the 5spd especially if the trans your installing has alot of miles on it
Mar 12, 2020 12:06 AM
MaxStock
Dec 5, 2016 05:19 PM
spencerwh1
Jun 30, 2016 05:44 AM
Socalstillen
Sep 20, 2015 11:46 PM
pktaske
Sep 4, 2015 08:40 AM
