Brake and Battery light combo..
Old Feb 3, 2005 | 07:54 AM
Brooklyn Legend's Avatar
I got timing belt and water pump changed yesterday an about an hour after leaving the shop I noticed the brake light and battery light on the dash would come on when I punched on the gas pedal. It only happens for a second or so and then goes away. I also notice it only happens when I hit the gas hard. Any takes on what might cause this?
Old Feb 3, 2005 | 08:06 AM
internetautomar's Avatar
mod or sell?
belt slipping on the alternator
Old Feb 3, 2005 | 08:11 AM
what can be done to fix tighten bolt on pulley for alternator?
Old Feb 3, 2005 | 08:15 AM
mod or sell?
change the belt, the pulley itself probably is not loose.
Old Feb 3, 2005 | 01:55 PM
all the belts were changed along with the timing belt, the alternator belt is on tight. and the alternator is 1 week old. Im stuck... What else could it be?
Old Feb 3, 2005 | 02:14 PM
Matt93SE's Avatar
STFU n00b!
check the wiring and make sure nothing's loose ont he alternator.
I had that problem several months ago. turned out to be a cut in the wire from some shoddy body repair work when a previous owner had it. the wires were pinched against the core support and cut, but they just taped them back together and put the car back together. I had the car for over 3 years before it started doing anything.. strange..
anyway, check your wiring. they may have disconnected something on the alternator or battery while they were working on the car.
Old Feb 4, 2005 | 07:12 AM
You had the same problem brake and battery light.
I can understand battery light for alternator but brake light?
Old Feb 4, 2005 | 07:18 AM
bhunter's Avatar
Mine did the same thing when the alternator went bad. For some reason the battery light AND the brake light come on. That confused me too.
Old Feb 4, 2005 | 07:59 AM
Matt93SE's Avatar
STFU n00b!
yes, both lights are on the same circuit. exactly why, I can't explain.. but that's the way it is. I looked it up in the service manual. They're only separated by a diode so that when you have brake problems, only your brake light comes on. when you have battery problems, both lights come on. stupid, yes. but that's the way it is.
Old Feb 4, 2005 | 08:38 AM
«§»Craig B«§»'s Avatar
it states in the owner's manual that brake and battery lights together mean alternator is not working properly. No idea why Nissan chose that combo.
tsi6001
Oct 3, 2022 10:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
