Engine questions
Old Feb 4, 2005 | 09:28 AM
mtnbikeair's Avatar
Engine questions
This is kind of moving on from the window tinting where i got side tracked..
Would a JDM engine like this one give me more power than a regular maxima engine would, or is it any different? Would i be better of going to a junkyard for a new engine? http://cgi.ebay.com/ebaymotors/ws/eB...951710093&rd=1
Thanks in advance!
Old Feb 4, 2005 | 09:37 AM
internetautomar's Avatar
mod or sell?
HP for "JDM" motor is the same as our "USDM" motors.
I can buy a complete max for that kinda money.
Old Feb 4, 2005 | 09:56 AM
mtnbikeair's Avatar
So the junkyard is still the best idea?
Old Feb 4, 2005 | 09:57 AM
mtnbikeair's Avatar
"if you want to go faster you have to spend more money.
Cams.
Higher compression pistons.
Turbo....."
As you said earlier, i dont mind spending too much more money as long as its within reason, because if im going to be going to alot of work to fix it, why not just save up a little more money and fix it up even better. But how much for like cams and higher compression pistons?
Old Feb 4, 2005 | 11:08 AM
mod or sell?
I think the cams are in the $300 range (maybe more)
Pistons are same ballpark.
BTW thise prices are only guesstimates on new ones.
Used I have no clue what the pricing is like
Old Feb 4, 2005 | 11:48 AM
mtnbikeair's Avatar
Okay, another question then is, should i just get a used motor from the junk yard and spend that estimated 6 hundred dollars towards something else for the car to make it faster?
Old Feb 4, 2005 | 11:59 AM
subs1000w's Avatar
the sad thing is cams and high compression pistons not to mention every other bolt on for a VG max still wont out perform a stock VE
Old Feb 4, 2005 | 12:04 PM
mtnbikeair's Avatar
So maybe i should just upgrade to a newer maxima??
Old Feb 4, 2005 | 12:13 PM
DanNY's Avatar
Ad·min·is·tra·tor
best idea i've heard u come up with today.
Old Feb 4, 2005 | 12:52 PM
HTPerformance's Avatar
92-94 SE 5 spd would be your best upgrade on the budget...
Old Feb 4, 2005 | 01:40 PM
mtnbikeair's Avatar
How much does a cheap one of those go for, and how much could i sell a 1990 GXE with 94xxx miles for?
Old Feb 4, 2005 | 02:15 PM
subs1000w's Avatar
your cars proboly worth 2-2.5k
and ve 5spd range from 1 to 6k depending on condition and milage
check auto trader and see if there are any in your area
Old Feb 4, 2005 | 02:51 PM
mtnbikeair's Avatar
should i try and buy one about the same price i sell mine for, or get more of a fixer upper, or a nicer one? Is the DOHC an engine that holds up better or worse or what?
MAXSE5SPD
Sep 17, 2022 04:00 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Hawkeye61
Aug 12, 2015 06:45 PM
