Removal of door panel on a 91
Old Feb 4, 2005 | 08:01 PM
Eric95se's Avatar
I don't really want to buy the manual just to remove the 2 front door panels... Can anyone help me out? I found the 2 screws under the caps near the hinge, and the screw in the handle (do I really need to take that one off?) Which way do the window switches come off? Thanks for everything!
Eric
PS: has anyone retrofitted 6.5 in spkrs on the back dash?
Old Feb 4, 2005 | 08:28 PM
Michael's Avatar
Back in a 3rd Gen.
after you take the 2 in the front you have to take the pull handle off. To do this there is a little black oval shaped piece that conceals the screw on the top back side of the handle. Take a small screwdriver and pry that out. Then there is a screw behind it. take that screw out. Then look inside where the actual door handle is and there is a small cover that you need to remove with a small flat head. Once that is out there is a screw strait down adn also one where the pull handle meets the door (up a little and into the hole). After the handle is off and you have the other screw out (strait down screw) then you have to pull the switches out. To do this you pull up on one end and it will come out easily. Then there is one final screw that is directly under there I believe.
Pop the bottom out and pull up because the top locks into the window channel.
hopefully that wasnt too confusing. I have taken them off a bunch of times but am not the best at explaining if I am not looking directly at it.
Old Feb 4, 2005 | 09:17 PM
«§»Craig B«§»'s Avatar
check my window regulator page
Old Feb 4, 2005 | 09:39 PM
Michael's Avatar
Back in a 3rd Gen.
thats where it was. I knew it was on your page somewhere and was going to save myself from typing but couldnt remember where it was (didnt look that hard when I went over there either like a dummy).
ef9
Sep 29, 2015 11:29 PM
95naSTA
Sep 21, 2015 06:50 PM
lkiller123
Sep 21, 2015 03:00 AM
carid
Sep 17, 2015 05:00 AM
