Old Apr 29, 2001 | 12:49 PM
MILLENIUM MAX
ok guys i plan on getting a set of 18inch adr gt-sport wheels which has a 42mm offset.My question is would this fit and look flush with the fender or will they look too far into the fender,and if spacers will be needed what size would i need?
Old Apr 29, 2001 | 05:17 PM
NYCe MaXiMa's Avatar
WHere are you getting them from?
If it's from whalentire.com or some website, make sure it's the right bolt pattern..... I'm not sure if 42 will work. Anything 38-42 should though.. You won't need spacers unless you can't clear the calipers, you might have a problem in the rear with rubbing the strut, for some reason i was awfully close to the strut when I had 99 5 spoke 16 X 6.5"'s so I got 1/4" spacers only in the rear, but then I had some 17 x 8" rims on with 235/45/17 tires and no rubbing problems what so ever, good clearence.
Old Apr 29, 2001 | 07:32 PM
MILLENIUM MAX
Yes the wheels are from whalentire and the bolt patteren is 5-114.3(4.5)which would fit the max.Well thanks for the help nyc max.
