Knock sensor replacement
Old Feb 7, 2005 | 04:32 PM
Dj Paul's Avatar
Do i need to replace my gaskets and stuff if i am taking out my intake manifold? I am just trying to replace my knock sensor and it sounds like i gotta replace a lot of crap.
Old Feb 7, 2005 | 04:55 PM
Cliff Clavin's Avatar
Way out West
better do it now while you have it apart. replace everything you can and you won't have to worry about it down the road.
There is a write up in the stickies on replacing your KS, BTW.
Old Feb 7, 2005 | 05:34 PM
internetautomar's Avatar
mod or sell?
just get a complete intake manifold set and a knock sensor, some people also recommend doing the harness at the same time.
of course there are people who do the KS without pulling the intake
Old Feb 7, 2005 | 05:49 PM
Way out West
I forgot about the harness. If you get the KS from Courtesy, they have a package with the harness, too.
Old Feb 7, 2005 | 05:50 PM
jwmaxse's Avatar
You can do it on a 4th gen without pulling the intake but not a VE.
I'd definitely recommend just buying new gaskets for it, you don't want to do the whole job and then have a leak and have to do it all over again. I would also recommend doing the harness at the same time, trust me it's not fun doing a KS on your car more than once...
Old Feb 8, 2005 | 07:54 AM
mod or sell?
It's been done, my buddy says he has the scraped knockles to prove it.
Old Feb 8, 2005 | 07:57 AM
Mizeree_X's Avatar
Getting back to his roots
This I'd like to hear. How does he remove the water pipe without taking off the IM? I still think he's referring to a VQ, because scraped knuckles are commonplace with KS replacement on that engine.
Old Feb 8, 2005 | 08:39 AM
mod or sell?
I don't talk to him much but he says the car looks like mine.
and now it has a "knock" still trying to get the guy to give me the car
Old Feb 8, 2005 | 08:54 AM
Jeff92se's Avatar
I'm needing a caw
There is no effin' way you can even THINK about replacing a VE KS without taking off the upper/lower IM and the coolant tube. In fact, even with the manifolds off and the tube on, you still couldn't replace it.
Old Feb 8, 2005 | 09:22 AM
lophix's Avatar
It WILL suck if there was an easier way to do it....then again, it wasn't really difficult to do; just time consuming.
Old Feb 8, 2005 | 10:57 AM
Jeff92se's Avatar
I'm needing a caw
See that tube running inbetween the heads? Let me know how to get a wrench around this to access the KS. And this is with the manifolds off.
Old Feb 8, 2005 | 11:19 AM
jwmaxse's Avatar
You can do anything if you put your mind to it Jeff
And I'm pissed that you locked the civic thread....
Old Feb 9, 2005 | 01:59 PM
Jeff92se's Avatar
I'm needing a caw
Wait. I take that back. You can access the KS w/o removing that tube
Old Feb 9, 2005 | 02:13 PM
Matt93SE's Avatar
STFU n00b!
you might be able to get a wrench on it, but good luck backing that bolt out with a socket on your wrench and getting the whole thing back out...
I highly recommend just pulling the tube, cleaning the whole area, and replacing all gaskets, your water pump, and checking for any other problems while you're in there. you do this once in the lifetime of the car- you might as well spend another couple of hours and do it right.
Old Feb 9, 2005 | 02:16 PM
Jeff92se's Avatar
I'm needing a caw
Matt. I was kidding.
Plus if you have the intakes off, it's only a few more bolts to get the tube off.
Old Feb 9, 2005 | 02:17 PM
mod or sell?
you owned urself
Kinda
Sorta
Not really
Old Feb 9, 2005 | 02:46 PM
Dj Paul's Avatar
i replaced 3 things with air breathers, the crankcase vent thing, one that is right next to the oil one, and one that was coming out the other side of that tube behind the maf. Im plugging up the tube with some plumbing ends and just increasing the airflow to everything. i put some jb weld under and around a bit and im waiting for it to sit, so i can finally get that stupid bolt out and replace my knock sensor. ill send a pic of what i did after all this crap is done. thanks guys
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
