power to antenna, but no power to radio
Old Feb 10, 2005 | 03:02 PM
ninjarider's Avatar
Hi all: I have a 93 Maxima, VE30DE. The radio and fan were turning on and off intermittently while driving, i.e. either both work or both turn off, so I opened up the front panel to locate the problem. No success in finding the problem, but now when I try to hook up the radio again, the antenna shoots up immediately, but there's NO power to the radio, even though the fan works. I tried this with the car engine on and off. Can't make any sense of it. Front fuses are fine. Can someone help ?
Thanks !
Old Feb 10, 2005 | 05:42 PM
internetautomar's Avatar
mod or sell?
something is shorting somewhere.
I don't envy you trying to tack it down
Old Feb 10, 2005 | 09:54 PM
ninjarider's Avatar
Any techniques u guys can suggest ? Has anyone had a problem with fuse oxidation type of loose contact or is this a wiring issue ?
Old Feb 11, 2005 | 03:27 PM
sackz23's Avatar
Same thing!
That's insane b/c the exact same thing happened to me about 15 minutes ago.
I was trying to fix my power antenna and then when I got it working the radio does not turn on at all. On top of that, my keyless pads are working either!
Any electric help would rock.
Old Feb 12, 2005 | 04:32 PM
mod or sell?
fuse is blown, not the radio one though
Old Feb 12, 2005 | 08:57 PM
sackz23's Avatar
Yup!
Just figured it out like 4 hours ago (posted the same topic in the Audio/Electric forum).
Looks like the Electric Bat fuse was blown. Replaced it. Works like a champ
Old Feb 13, 2005 | 06:08 PM
ninjarider's Avatar
Guys, I found out that the radio will not work unless I plug in the antenna connection, which is the single connection in the corner of the radio back panel opposite to the composite connector. Is the circuit inside wired in such a way that the CD player/ radio will not receive power without the antenna connected? Does anyone know how the antenna connector is different from the power antenna connection in the composite connector (blue wire) ?
sackz23, I read your post, but didn't find info on where the electric bat fuse is located. can you please specify ? thanks for the help !
chisam14
Nov 6, 2018 08:56 PM
leatherneck
Sep 30, 2015 09:16 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
