What is the PCV ?
Old Apr 30, 2001 | 10:50 AM
wizard6161's Avatar
I been hearing about it for a while now but I don't know what it is or what does it do. Also when do you have to replace it? is there a certain signs to tell you ? thanks for the help .
Old Apr 30, 2001 | 01:41 PM
MadMaxBrent's Avatar
What the ...
PCV = Positive Crankcase Ventilation (valve)
Under idle conditions the valve is closed. The valve is a spring plunger variety and is actuated by the intake manifold pressure. As the car revolutions increase the plunger opens allowing the crankcase to vent back into the intake where it is then combusted. Overtime these valves get clogged and stick open. When this happens you may experience an uneven idle.
You can check the operation of the PCV by removing it from the car and giving it a shake. You should hear it rattle like a spray can. If no, then it is probable stuck open.
El Cheapo fixo is to soak the valve in some mineral turps (or the like) but since this is a cheap and easy maintenance item it is best to just replace if in doubt.
Hope this helps your understanding.
Brent
Old Apr 30, 2001 | 03:49 PM
Cincy94Max's Avatar
What does the hose connected to the PCV valve connect? The upper intake manifold and the ??????
Old Apr 30, 2001 | 03:53 PM
Connected to
From memory it connects to the rear valve cover (crankcase).
bumpypickle
Sep 20, 2015 08:22 AM
lowpost99
22
Sep 2, 2015 04:38 PM
maxinout93
Aug 20, 2015 02:17 AM
puch
Feb 25, 2002 03:28 PM
Dave B
Aug 28, 2001 09:47 AM
