2 inch lower heights.
Old Feb 12, 2005 | 10:33 AM
95turbo gxe's Avatar
I bought a set of springs from a org member a while back and they clamed to be 2inch sprint lower springs. (RED ON COLOR) Ok I have 225/45/17s and these spings on the car what should the height be from the ground to the fender be. (ON normal flat ground) Maybe someone could measure it too see.
Old Feb 12, 2005 | 10:46 AM
Michael's Avatar
Back in a 3rd Gen.
You just have to put them on and see. I have seen Sprint be so different on so many Maximas that I doubt you can get an accurate measurement.
Old Feb 12, 2005 | 11:17 AM
their on the car now
Old Feb 12, 2005 | 11:28 AM
Michael's Avatar
Back in a 3rd Gen.
Ohhh I gotcha...you want to compare your ride height with the ride height of others with sprints. My bad...I can give you my height with Intrax (I know thats not what you asked for) and 225/40/18s (should be about the same height as your tires).
My height on all 4 corners is 25" at the center of the wheel well. I just checked and they are all 4 the exact same height and are exactly 25" from the ground. Now I just put my wheels back on and had it jacked up for a little while so I dont know if they will settle down a little or not (they look a tad higher but dunno). I will check in a couple of days to see if they change any.
EDIT: I have no amps or subs in the car either. That is without any added weight in the rear of the car.
Old Feb 12, 2005 | 11:31 AM
Thanks man. ANy other with sprint red springs out their let me know please.
Old Feb 12, 2005 | 12:50 PM
505max94se's Avatar
Does anyone know the ddifference between the red sprint springs and the blue sprint spings?
Old Feb 13, 2005 | 02:10 AM
nubiannupe's Avatar
OG Maxima.org Member
IIRC, the blue ones (I own/ride on a set) are the "Extreme" series - roughly a 3+ inch drop after settling. All I know is that my wheels are tucked in pretty well now. I'm probably gonna go back to stock this summer, though, unless I can find or buy a little LESS agressive drop.
As for your question, 93turbo gxe... since I'm on my 15" OEM "winter" wheels, I can only get you measurements along those lines. I know that when I put on my 17" summer wheels (see sig pic), there's less than a finger of space from the top of my tire and the upper edge of the fender well. If that helps out any....
Old Feb 13, 2005 | 10:54 AM
goon9's Avatar
3+ drop?
I got blue ones. dropped m roughly 2 inches.
Old Feb 13, 2005 | 01:29 PM
505max94se's Avatar
I have blue ones too and the drop is roughly 2 inches. I wonder if the spring rate is differentfrom the reds.
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
