I'm leaking oil, wheres the problem?
I have an oil leak coming from the right side of engine, I'm assuming near a pulley since there is oil all over the right side of car axle, control arm, etc... I have 160,000 miles where is the most likely place the leak is coming from?
This sounds like a PITA. Is this a DIY job? If not how much $ am I gonna have to plunk down at a shop? Also is there anything else I should have replaced while having this seal replaced while my car is in the shop?
It really is not too difficult if you do it yourself and you will save yourself some money. Heck if you want you can buy an underdrive pulley and reward yourself for doing it yourself
Basically just jack up the car, remove the tire (gives you the most space), take off the pulley bolt. Then you can just take out the old seal, put in the new one, install the pulley again, put the wheel back on and walla!
There is a chance it could be the oil pan. It is slightly more difficult but you can do it.
.Basically just jack up the car, remove the tire (gives you the most space), take off the pulley bolt. Then you can just take out the old seal, put in the new one, install the pulley again, put the wheel back on and walla!
check www.4dsc.com/articles for the UDP install and that'll show you what to do
kjlouis
Oct 3, 2015 05:29 AM
markevans999
Sep 10, 2015 04:29 PM
