paint question
Old Feb 15, 2005 | 04:18 PM
magicdonjohn's Avatar
paint question
for those guys who may have painted their own car, how many quarts or pints of paint and how many quarts or pints of clear coat did you get to complete the job?
Old Feb 15, 2005 | 04:59 PM
Michael's Avatar
Back in a 3rd Gen.
depends on what you are doing.
The general consensus is that you need a gallon of sprayable paint (depending on paint...but usually 2qts color, 2qts reducer). That may vary with the cheaper line of paints because the coverage isnt as well. Now if you are changing colors and need to paint inside the doors, trunk and hood then it will obviously be more.
For clear you might as well just say a gallon of actual clear and then however much reducer/hardener/activator (depeding on brand) it uses.
Spray the base until hiding and then 2 coats of clear (most clears are 2 coat clears now a days) 3 coats if you plan on wet sanding and buffing. You dont want too much clear or you will get solvants trapped under the clear and it will come out causing pin holes and other problems later on.
Old Feb 15, 2005 | 05:05 PM
mike ur in MS with me. how much would u charge me if i got everything. myne is just like yours except i have the spoiler
Old Feb 15, 2005 | 05:34 PM
Michael's Avatar
Back in a 3rd Gen.
depends on when you want it done and what you want done.
email me and we can talk...email is in my sig above.
doctorpullit
Apr 23, 2017 05:35 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Luigi623
Sep 21, 2015 01:42 PM
pears
Sep 18, 2015 05:25 AM
